メインコンテンツにスキップ
Philips Steam Iron GC 1905 Power Cord Replacement
必要な工具と部品
  1. Philips Steam Iron GC 1905 Power Cord Replacement, Power cord replacement: 手順 1、 1の画像 1
    • Switch off and unplug the iron. Drain the water from the water tank.
    • To prevent damage to the soleplate of the iron, make sure the worktop surface is non-abrasive.
    • Make sure the iron has cooled down before you start disassembly.
  2. Philips Steam Iron GC 1905 Power Cord Replacement: 手順 2、 2の画像 1 Philips Steam Iron GC 1905 Power Cord Replacement: 手順 2、 2の画像 2
    • Turn over to the triangular backplate of the steam iron.
    • Remove the 10.0 mm screw securing the backplate to the main body with a Phillips #1 screwdriver.
  3. Philips Steam Iron GC 1905 Power Cord Replacement: 手順 3、 3の画像 1 Philips Steam Iron GC 1905 Power Cord Replacement: 手順 3、 3の画像 2 Philips Steam Iron GC 1905 Power Cord Replacement: 手順 3、 3の画像 3
    • Wedge your thumb and fingers at the joint between the backplate and the handle to loosen the snap joints.
    • Be mindful of the snap joints as they may break if excess pressure is applied.
    • We advise against use of screwdriver to pry open the backplate as it may damage snap joints.
    • Pull out the backplate gently to reveal the electric circuit—it will be still be connected to the wires so don't yank it off.
    • Take a photo of the electrical circuit to use as reference in step 5.
  4. Philips Steam Iron GC 1905 Power Cord Replacement: 手順 4、 3の画像 1 Philips Steam Iron GC 1905 Power Cord Replacement: 手順 4、 3の画像 2 Philips Steam Iron GC 1905 Power Cord Replacement: 手順 4、 3の画像 3
    • Grip the green cable as close to the crimp connector as possible.
    • For easy removal, pinch the crimp connector between your thumb and forefinger. Apply force to the connector rather than the cable.
    • Slide out the crimp connector attached to the cable.
    • Applying force to the cable might separate the wire from the connector and leave the crimp connector in the slot.
    • Repeat the previous step to remove the red and black cables and take out the power cord.
  5. Philips Steam Iron GC 1905 Power Cord Replacement: 手順 5、 3の画像 1 Philips Steam Iron GC 1905 Power Cord Replacement: 手順 5、 3の画像 2 Philips Steam Iron GC 1905 Power Cord Replacement: 手順 5、 3の画像 3
    • To connect the new cables, align and slide the crimp connector on the green cable into vacant slot.
    • Repeat the above step for the red and black cables.
    • Make sure the green, red and black cables are inserted in the correct slots.
  6. Philips Steam Iron GC 1905 Power Cord Replacement: 手順 6、 1の画像 1
    • Before reassembly, ensure that the cord does not obstruct the screw slot.
終わりに
Happy Fixing!
5 の人々がこのガイドを完成させました。
作成者
2人の作成者と共同で作成されました。
Miraan Dilawari
メンバー登録日: 09/06/21
283 ポイント
1ガイドが承認済み
チーム
York University, Team 1-5, O'Regan Fall 2021 York University, Team 1-5, O'Regan Fall 2021人のメンバー
YORK-O'REGAN-F21S1G5
1 メンバー
2のガイドは作成済み
2 件のコメント
het l'ange deksel was al door mij losgemaakt
2 klips in het midden ...kon niet verder Los krijgen
wat moet ik verser doen zonder stukken te maken stroomdraad is stuk ????
QUISQUATER ETIENNE - 返信
But where do I find new wire online
Bharath Reddy - 返信
コメントを追加
統計データ:
過去 24時間: 6
過去 7 日: 35
過去 30 日: 195
今までの合計 6,831
