メインコンテンツにスキップ
Philips Sonicare ProtectiveClean 6500 Power Button, Mode Button Replacement
必要な工具と部品
  1. Philips Sonicare ProtectiveClean 6500 Power Button, Mode Button Replacement, Internal Assembly: 手順 1、 3の画像 1 Philips Sonicare ProtectiveClean 6500 Power Button, Mode Button Replacement, Internal Assembly: 手順 1、 3の画像 2 Philips Sonicare ProtectiveClean 6500 Power Button, Mode Button Replacement, Internal Assembly: 手順 1、 3の画像 3
    • Pry the bottom cap away from the toothbrush body.
    • Pry the bottom cap away from the toothbrush body until it releases.
    • Remove the bottom cap by hand.
  2. Philips Sonicare ProtectiveClean 6500 Power Button, Mode Button Replacement: 手順 2、 2の画像 1 Philips Sonicare ProtectiveClean 6500 Power Button, Mode Button Replacement: 手順 2、 2の画像 2
    • Use a metal spudger to release the two retaining clips inside the device.
    • The clips release when pried inward.
  3. Philips Sonicare ProtectiveClean 6500 Power Button, Mode Button Replacement: 手順 3、 2の画像 1 Philips Sonicare ProtectiveClean 6500 Power Button, Mode Button Replacement: 手順 3、 2の画像 2
    • Slide the internal assembly out of the chassis.
  4. Philips Sonicare ProtectiveClean 6500 Power Button, Mode Button Replacement, Power Button, Mode Button: 手順 4、 2の画像 1 Philips Sonicare ProtectiveClean 6500 Power Button, Mode Button Replacement, Power Button, Mode Button: 手順 4、 2の画像 2
    • Locate the power button (solder locations circled in orange).
    • Locate the mode button (solder locations circled in red).
    • Both buttons are attached by four soldered pins each.
  5. Philips Sonicare ProtectiveClean 6500 Power Button, Mode Button Replacement: 手順 5、 2の画像 1 Philips Sonicare ProtectiveClean 6500 Power Button, Mode Button Replacement: 手順 5、 2の画像 2
    • Heat the soldering iron.
    • Soldering can cause burns and fires. Always solder in a well-ventilated area.
    • To test if the soldering iron is ready, place on the solder and if the solder melts easily and quickly, your soldering iron is ready.
    • Use the soldering iron to desolder all of the connections.
  6. Philips Sonicare ProtectiveClean 6500 Power Button, Mode Button Replacement: 手順 6、 2の画像 1 Philips Sonicare ProtectiveClean 6500 Power Button, Mode Button Replacement: 手順 6、 2の画像 2
    • Use tweezers to remove the buttons from the board.
    • Place new button onto board and repeat previous steps in reverse to reassemble.
終わりに
作成者
2人の作成者と共同で作成されました。
Liam Casto
メンバー登録日: 04/01/24
354 ポイント
3のガイドは作成済み
チーム
IUPUI, Team 1-4, Harley Spring 2024 IUPUI, Team 1-4, Harley Spring 2024人のメンバー
IUPUI-HARLEY-S24S1G4
3 メンバー
3のガイドは作成済み
0 Guide Comments
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 11
過去 30 日: 30
今までの合計 231
