はじめに
If the UV light bulb in your Philips Sonicare FlexCare Sanitizer charging port is no longer working and needs to be replaced, follow these 4 step-by-step instructions. Following these instructions carefully will ensure that the light bulb will be replaced in an efficient manner and work to establish the port status once again. To reassemble the product after replacement of the light bulb, follow the steps in reverse order.
Before initiating the process, ensure that the sanitizer is not plugged into an outlet. Swing the door open to expose the interior of the sanitizing device.
Before holding the light bulb, ensure that it is not warm due to previous use. Once that is confirmed, take a hold of the light bulb by the threaded surface and rotate it while pulling it outward. Have a compatible UV bulb to replace the old one.
What kind of bulb does it take?
I have two bulbs from #200618 and # 5615 this is my first time wanting to order replacemnts. None of the ads show the bulb number so how do I order the one I need?
The guide is very easy to follow and I appreciate the instructions.
Where to obtain the correct bulb?
6 の人々がこのガイドを完成させました。
6 件のコメント
Just changed the bulb and it still does not work :( :( :(
I've had mine for close to 10 years I'm just now having to change my UV bulb
Hi all, pls what is type of bulb and where to buyt it ?
