メインコンテンツにスキップ
Philips Sonicare FlexCare UV Light Bulb Replacement
  1. Philips Sonicare FlexCare UV Light Bulb Replacement, UV Light Bulb: 手順 1、 1の画像 1
    • Before initiating the process, ensure that the sanitizer is not plugged into an outlet. Swing the door open to expose the interior of the sanitizing device.
  2. Philips Sonicare FlexCare UV Light Bulb Replacement: 手順 2、 1の画像 1
    • Grip the sides of the plastic cover that is shielding the circuitry. Pull the cover outward to remove it from the sanitizer.
  3. Philips Sonicare FlexCare UV Light Bulb Replacement: 手順 3、 2の画像 1 Philips Sonicare FlexCare UV Light Bulb Replacement: 手順 3、 2の画像 2
    • Squeeze the sides of the guard that is placed over the UV light bulb. Pull the piece outward to remove it.
  4. Philips Sonicare FlexCare UV Light Bulb Replacement: 手順 4、 2の画像 1 Philips Sonicare FlexCare UV Light Bulb Replacement: 手順 4、 2の画像 2
    • Before holding the light bulb, ensure that it is not warm due to previous use. Once that is confirmed, take a hold of the light bulb by the threaded surface and rotate it while pulling it outward. Have a compatible UV bulb to replace the old one.
終わりに
6 の人々がこのガイドを完成させました。
作成者
6人の作成者と共同で作成されました。
Tasha Panattoni
メンバー登録日: 04/14/15
789 ポイント
2のガイドは作成済み
チーム
Cal Poly, Team 4-6, Maness Spring 2015 Cal Poly, Team 4-6, Maness Spring 2015人のメンバー
CPSU-MANESS-S15S4G6
4 メンバー
23のガイドは作成済み
6 件のコメント
I’ve had mines less than a year. The uv lamp makes a “whizz sound for a second and then stops. No noise. No light. Does the bulb needs to be replaced ? Is it normal for it to die in 9 mths?
Uroos ali - 返信
I’ve had my unit for over 7 years, I was getting ready to replace it. Thanks so much, I’m not a handy person and I’m really pleased to see that I could fix this problem with your helpful advice!
roleplay1 - 返信
Just changed the bulb and it still does not work :( :( :(
nicoleproulx47 - 返信
Do UV bulbs need changing on a yearly basis or are they still good if giving out light?
jujsf - 返信
I've had mine for close to 10 years I'm just now having to change my UV bulb
Christopher Hurtle - 返信
コメントを追加
統計データ:
過去 24時間: 4
過去 7 日: 27
過去 30 日: 66
今までの合計 11,994
