はじめに
If the UV light bulb in your Philips Sonicare FlexCare Sanitizer charging port is no longer working and needs to be replaced, follow these 4 step-by-step instructions. Following these instructions carefully will ensure that the light bulb will be replaced in an efficient manner and work to establish the port status once again. To reassemble the product after replacement of the light bulb, follow the steps in reverse order.
Before initiating the process, ensure that the sanitizer is not plugged into an outlet. Swing the door open to expose the interior of the sanitizing device.
6 の人々がこのガイドを完成させました。
6 件のコメント
Just changed the bulb and it still does not work :( :( :(
I've had mine for close to 10 years I'm just now having to change my UV bulb
