メインコンテンツにスキップ
修理を始めるには
修理する権利
ストア
  1. Pull the brush head away from the handle to remove it.
    • Pull the brush head away from the handle to remove it.
  2. Push the flat edge of a metal or nylon spudger between the seal and the toothbrush body and pry it open. Do this all around the edge until the seal is partially sticking out.
    • Push the flat edge of a metal or nylon spudger between the seal and the toothbrush body and pry it open. Do this all around the edge until the seal is partially sticking out.
  3. Apply pressure to the shaft by pressing it against a firm and flat surface. Continue to apply pressure until the electronics located in the interior are exposed. Apply pressure to the shaft by pressing it against a firm and flat surface. Continue to apply pressure until the electronics located in the interior are exposed.
    • Apply pressure to the shaft by pressing it against a firm and flat surface. Continue to apply pressure until the electronics located in the interior are exposed.
  4. Grab the circular, plastic base with the o-ring and pull it outward.
    • Grab the circular, plastic base with the o-ring and pull it outward.
  5. Using a #00 phillips head screwdriver, loosen the screw completely.
    • Using a #00 phillips head screwdriver, loosen the screw completely.
  6. Rotate the interior of the toothbrush until the screw  is facing downward. Slightly shake the interior so that the screw with its accompanying metal part fall out.
    • Rotate the interior of the toothbrush until the screw is facing downward. Slightly shake the interior so that the screw with its accompanying metal part fall out.
    • Slightly shake the interior so that the screw falls out.
    • A small ring may fall out when the screw is removed. Be careful not to lose the ring.
  7. Use a metal probe to press against the hole located at the edge of the interior. While applying this pressure, pull on the shaft outward. Repeat this step on the opposite side.
    • Use a metal probe to press against the hole located at the edge of the interior. While applying this pressure, pull on the shaft outward. Repeat this step on the opposite side.
    • A small nut may fall out when the shaft is removed. Be careful not to lose the nut.
  8. Once the shaft is released, separate it from the body of the interior.
    • Once the shaft is released, separate it from the body of the interior.
    • Insert the replacement shaft by aligning the the components and applying a force to insert the legs (one of the legs is identified by the red arrow) of the shaft into the interior.
終わりに
32 の人々がこのガイドを完成させました。
Tasha Panattoni
メンバー登録日: 2015年04月14日
574 ポイント
2のガイドは作成済み
チーム
Cal Poly, Team 4-6, Maness Spring 2015 Cal Poly, Team 4-6, Maness Spring 2015人のメンバー
CPSU-MANESS-S15S4G6
4 メンバー
13のガイドは作成済み
29 件のコメント
Where do you get a replacement shaft? I can't find any online
noahmckinnon - 返信
You don't need to pry the bottom plate off and risk damaging the seal. Simply apply firm pressure on the shaft against a table while simultaneously wiggling the bottom plate back and forth with a large flathead screwdriver inserted into the charging hole on the bottom. It will pop off smoothly leaving the seal untouched and not scratching the housing or charging plug.
jelneutron3 - 返信
I can not find the shaft anywhere who sells them
bennie - 返信
Like the previous comments I also am looking for the replacement shaft. If anyone has found a source please leave a comment with regards to where they can be found.
Thanks for the help
Lino Valadas - 返信
Like everyone above, I can't locate the "replacement shaft". Anyone have any ideas who might have one? A $179 toothbrush should last more than the one year warranty! Is the Braun Oral-B any better?
pgootos - 返信
コメントを追加
統計データを表示:
過去 24時間: 56
過去 7 日: 421
過去 30 日: 2,196
今までの合計 86,274
