はじめに
If the epilator is plugged in and receiving power, but still will not turn on, one of the internal components may be broken. This guide will help you remove a broken motor of your Philips Satinelle. It should take no more than 30 minutes to complete this guide.
必要な工具と部品
Pull the plastic casing apart with your hands.
That means once the epilator is opened, the same cover cannot be used to enclose the machine??
Renu Singh - 返信
ある他の人がこのガイドを完成しました。
