はじめに
Use this guide if you need to replace the gear that turns the tweezers of your Philips Satinelle.
必要な工具と部品
Unplug the device and remove the purple guard.
Remove the head by pressing the right side of the head (with the device facing away from you).
You will hear a 'click' and the head will become dislodged from the body of the device.
Replace the gear and re-insert the pin.
Ensure that pin is protruding slightly, it should not be flush.
3 件のコメント
What size pinion is used in it? Kindly help.
Can you send link to buy this piece?
Or 3d Printer file?
Thanks
