メインコンテンツにスキップ
Philips SBA1060 Circuit Board Replacement
必要な工具と部品
  1. Philips SBA1060 Circuit Board Replacement, Battery Casing: 手順 1、 1の画像 1
    • Remove the back cover by sliding it off.
    • Remove the 3 AAA batteries.
  2. Philips SBA1060 Circuit Board Replacement: 手順 2、 3の画像 1 Philips SBA1060 Circuit Board Replacement: 手順 2、 3の画像 2 Philips SBA1060 Circuit Board Replacement: 手順 2、 3の画像 3
    • Unscrew the nine exterior screws on the back panel using a PH0-size Philips-head screwdriver.
    • A larger screwdriver head and more force may be required for damaged screws.
    • Remove the triangular end piece by pulling it straight off.
  3. Philips SBA1060 Circuit Board Replacement: 手順 3、 2の画像 1 Philips SBA1060 Circuit Board Replacement: 手順 3、 2の画像 2
    • Remove the colored grill by sliding it off in the direction of the removed end piece.
    • Pry off the back battery panel with the plastic opening tool.
    • Be careful to avoid tearing any wires.
  4. Philips SBA1060 Circuit Board Replacement, Circuit Board: 手順 4、 1の画像 1
    • Remove the two screws on opposite ends of the circuit board with the PH0 size philips head screw driver.
    • Remove the damaged circuit board from the device.
  5. Philips SBA1060 Circuit Board Replacement: 手順 5、 2の画像 1 Philips SBA1060 Circuit Board Replacement: 手順 5、 2の画像 2
    • Remove the battery plug from the circuit board by pulling out the plugs to fully remove back panel.
    • Remove the speaker plugs from the circuit board by pulling out the plugs. They are located on opposite sides of the circuit board.
    • NOTE: When reassembling, note that the speaker with the red wire goes to the red plug, and the speaker with the white wire goes to the adjacent white plug.
    • Remove the light plug from the circuit board.
    • NOTE: This plug is twice as wide as the speaker and battery plugs.
    • Reassemble the device.
終わりに
2 の人々がこのガイドを完成させました。
作成者
5人の作成者と共同で作成されました。
April Driscoll
メンバー登録日: 10/21/13
321 ポイント
3のガイドは作成済み
チーム
Clemson, Team 14-4, Benson Fall 2013 Clemson, Team 14-4, Benson Fall 2013人のメンバー
CLEM-BENSON-F13S14G4
3 メンバー
4のガイドは作成済み
2 件のコメント
Is that one of those cheap pam amps that run from 5v?
fabio souza jr - 返信
Nice picture,it helps a lot in trouble shooting !
sergio - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 5
過去 30 日: 16
今までの合計 1,316
