メインコンテンツにスキップ
修理を始めるには
修理する権利
ストア
はじめに
This guide will help the user replace the white plastic housing of the player, and will allow the user to replace inner parts.
パーツ
パーツは指定されていません。
  1. Lay the player flat so the bottom outside is showing. Using the Phillips #0 screwdriver, unscrew all the housing screws on the bottom of the player. Have the player sitting upright, remove the rubber stoppers in order to get to the screw. Unscrew the inside screws by the screen using the Philips #0 screwdriver. Remove the rubber stoppers for the bottom two screws as well. Unscrew the middle two screws.
    • Lay the player flat so the bottom outside is showing. Using the Phillips #0 screwdriver, unscrew all the housing screws on the bottom of the player.
    • Have the player sitting upright, remove the rubber stoppers in order to get to the screw. Unscrew the inside screws by the screen using the Philips #0 screwdriver.
    • Remove the rubber stoppers for the bottom two screws as well. Unscrew the middle two screws.
  2. Open the disc flap and remove the screws inside with the Phillips #0 screwdriver. There will be three screws. Open the disc flap and remove the screws inside with the Phillips #0 screwdriver. There will be three screws.
    • Open the disc flap and remove the screws inside with the Phillips #0 screwdriver. There will be three screws.
  3. Start removing the inside black face plate  of the player by using a prying method between the white outer housing and the black face plate with a metal spudger. Pull the black face plate off once you have pried it from the white housing. The bottom inside layer should pop off. Using the same prying method with the metal spudger, start prying off the screens white outer housing.
    • Start removing the inside black face plate of the player by using a prying method between the white outer housing and the black face plate with a metal spudger.
    • Pull the black face plate off once you have pried it from the white housing. The bottom inside layer should pop off.
    • Using the same prying method with the metal spudger, start prying off the screens white outer housing.
  4. The light panel on the front can just pop right off. To remove the metal bar against the battery, unscrew the screws with the phillips #0 screwdriver. After unscrewing you can just lift the metal bar off.
    • The light panel on the front can just pop right off.
    • To remove the metal bar against the battery, unscrew the screws with the phillips #0 screwdriver.
    • After unscrewing you can just lift the metal bar off.
終わりに
Julia Sheremet
メンバー登録日: 2015年09月28日
291 ポイント
2のガイドは作成済み
チーム
Eastern Washington University, Team 1-3, Matresse Fall 2015 Eastern Washington University, Team 1-3, Matresse Fall 2015人のメンバー
EWU-MATRESSE-F15S1G3
3 メンバー
4のガイドは作成済み
0 件のコメント
コメントを追加
統計データを表示:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 3
今までの合計 358
