メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Philips PD9000 37 Disk Drive Replacement
必要な工具と部品
    1. Philips PD9000 37 Disk Drive Replacement, White Outer Housing: 手順 1、 3の画像 1 Philips PD9000 37 Disk Drive Replacement, White Outer Housing: 手順 1、 3の画像 2 Philips PD9000 37 Disk Drive Replacement, White Outer Housing: 手順 1、 3の画像 3
      • Lay the player flat so the bottom outside is showing. Using the Phillips #0 screwdriver, unscrew all the housing screws on the bottom of the player.
      • Have the player sitting upright, remove the rubber stoppers in order to get to the screw. Unscrew the inside screws by the screen using the Philips #0 screwdriver.
      • Remove the rubber stoppers for the bottom two screws as well. Unscrew the middle two screws.
      FixBotに聞いてみる
      コメントを追加
    2. Philips PD9000 37 Disk Drive Replacement: 手順 2、 2の画像 1 Philips PD9000 37 Disk Drive Replacement: 手順 2、 2の画像 2
      • Open the disc flap and remove the screws inside with the Phillips #0 screwdriver. There will be three screws.
      FixBotに聞いてみる
      コメントを追加
    3. Philips PD9000 37 Disk Drive Replacement: 手順 3、 3の画像 1 Philips PD9000 37 Disk Drive Replacement: 手順 3、 3の画像 2 Philips PD9000 37 Disk Drive Replacement: 手順 3、 3の画像 3
      • Start removing the inside black face plate of the player by using a prying method between the white outer housing and the black face plate with a metal spudger.
      • Pull the black face plate off once you have pried it from the white housing. The bottom inside layer should pop off.
      • Using the same prying method with the metal spudger, start prying off the screens white outer housing.
      FixBotに聞いてみる
      コメントを追加
    4. Philips PD9000 37 Disk Drive Replacement: 手順 4、 3の画像 1 Philips PD9000 37 Disk Drive Replacement: 手順 4、 3の画像 2 Philips PD9000 37 Disk Drive Replacement: 手順 4、 3の画像 3
      • The light panel on the front can just pop right off.
      • To remove the metal bar against the battery, unscrew the screws with the phillips #0 screwdriver.
      • After unscrewing you can just lift the metal bar off.
      FixBotに聞いてみる
      コメントを追加
    1. Philips PD9000 37 Disk Drive Replacement, Disk Drive: 手順 5、 2の画像 1 Philips PD9000 37 Disk Drive Replacement, Disk Drive: 手順 5、 2の画像 2
      この手順で使用する道具:
      • Using the Tweezers from the iFixit repair tools, pull the two white plastic connectors that connect the disk drive to the motherboard off detaching the disk drive from the motherboard.
      FixBotに聞いてみる
      コメントを追加
    2. Philips PD9000 37 Disk Drive Replacement: 手順 6、 1の画像 1
      • Grab the sides of the disk drive and gently pull straight up to detach the disk drive.
      • The white ribbon is not connected to the actual drive, so it can be ignored.
      FixBotに聞いてみる
      コメントを追加
終わりに
キャンセル: このガイドを終了できませんでした。
2 の人々がこのガイドを完成させました。
作成者
5人の作成者と共同で作成されました。
Julia Sheremet
メンバー登録日: 09/28/15
303 ポイント
2のガイドは作成済み
チーム
Eastern Washington University, Team 1-3, Matresse Fall 2015 Eastern Washington University, Team 1-3, Matresse Fall 2015人のメンバー
EWU-MATRESSE-F15S1G3
3 メンバー
12のガイドは作成済み
1件のガイドコメント
Hi! Where I can buy the Philips PD9000 37 Disk Drive Replacement because I can´t find it... Thanks
Eduardo - 返信 共有
コメントを追加
統計データ:
過去 24時間: 3
過去 7 日: 10
過去 30 日: 55
今までの合計 4,585
