メインコンテンツにスキップ
Philips PD9000 37 Battery Replacement
必要な工具と部品
  1. Philips PD9000 37 Battery Replacement, White Outer Housing: 手順 1、 3の画像 1 Philips PD9000 37 Battery Replacement, White Outer Housing: 手順 1、 3の画像 2 Philips PD9000 37 Battery Replacement, White Outer Housing: 手順 1、 3の画像 3
    • Lay the player flat so the bottom outside is showing. Using the Phillips #0 screwdriver, unscrew all the housing screws on the bottom of the player.
    • Have the player sitting upright, remove the rubber stoppers in order to get to the screw. Unscrew the inside screws by the screen using the Philips #0 screwdriver.
    • Remove the rubber stoppers for the bottom two screws as well. Unscrew the middle two screws.
    Can you provide one for the bad motor and how to fix the problem. Please, email me at syaiugligs@gmail.com when you have the guidelines available.
    Thank you!
    Sylvester Yaiuglig - 返信
    The screws on the top of the screen and bottom are not necessary
    grace nicosin - 返信
  2. Philips PD9000 37 Battery Replacement: 手順 2、 2の画像 1 Philips PD9000 37 Battery Replacement: 手順 2、 2の画像 2
    • Open the disc flap and remove the screws inside with the Phillips #0 screwdriver. There will be three screws.
  3. Philips PD9000 37 Battery Replacement: 手順 3、 3の画像 1 Philips PD9000 37 Battery Replacement: 手順 3、 3の画像 2 Philips PD9000 37 Battery Replacement: 手順 3、 3の画像 3
    • Start removing the inside black face plate of the player by using a prying method between the white outer housing and the black face plate with a metal spudger.
    • Pull the black face plate off once you have pried it from the white housing. The bottom inside layer should pop off.
    • Using the same prying method with the metal spudger, start prying off the screens white outer housing.
  4. Philips PD9000 37 Battery Replacement: 手順 4、 3の画像 1 Philips PD9000 37 Battery Replacement: 手順 4、 3の画像 2 Philips PD9000 37 Battery Replacement: 手順 4、 3の画像 3
    • The light panel on the front can just pop right off.
    • To remove the metal bar against the battery, unscrew the screws with the phillips #0 screwdriver.
    • After unscrewing you can just lift the metal bar off.
  5. Philips PD9000 37 Battery Replacement, Battery: 手順 5、 2の画像 1 Philips PD9000 37 Battery Replacement, Battery: 手順 5、 2の画像 2
    • Take the metal rounded rectangle spudger and place under battery edge.
    • Avoid breaking plastic cover.
    • press down hard on held end of spudger, you will hear the battery un-stick.
  6. Philips PD9000 37 Battery Replacement: 手順 6、 2の画像 1 Philips PD9000 37 Battery Replacement: 手順 6、 2の画像 2
    • Use a soldering iron to melt the metal connecting the battery wires to the mother board.
    • Quickly remove each wire after melting the metal
    • Soldering iron is HOT and will burn you.
    • Wires will get HOT and may burn you.
  7. Philips PD9000 37 Battery Replacement: 手順 7、 1の画像 1
    • Properly dispose of battery as soon as possible
    • If battery is not disposed of, it may bloat and explode
    • If battery leaks, dispose of right away and wash hands.
終わりに
5 の人々がこのガイドを完成させました。
作成者
3人の作成者と共同で作成されました。
Kendal Cler
メンバー登録日: 09/28/15
951 ポイント
6のガイドは作成済み
チーム
Eastern Washington University, Team S4-G1, Crane Fall 2018 Eastern Washington University, Team S4-G1, Crane Fall 2018人のメンバー
EWU-CRANE-F18S4G1
2 メンバー
15のガイドは作成済み
3 件のコメント
Where can this battery be bought? After a year using, playing time is down to 3 hours
L.Johnson - 返信
Yeah. Where can I get the battery?
Bryan Allen - 返信
This tutorial is completely worthless if one doesn't have a battery to replace the one removed. Now two people have asked where to get a replacement yet you have not responded. Undoubtedly countless others have come by looking for a suitable replacement and saw that there was no response and no solution. Congratulations on helping no one. It would seem you're nothing more than a blowhard, a big show off, “Oh look at me I am fixing my bad battery. Aren't you impressed?” I'm not.
kurt - 返信
コメントを追加
統計データ:
過去 24時間: 3
過去 7 日: 14
過去 30 日: 51
今までの合計 7,366
