メインコンテンツにスキップ
Philips Norelco MultiGroom 3100 Battery Replacement
必要な工具と部品
  1. Philips Norelco MultiGroom 3100 Battery  Replacement, Power Button: 手順 1、 1の画像 1
    • Remove the comb from the top of the trimmer.
  2. Philips Norelco MultiGroom 3100 Battery  Replacement: 手順 2、 2の画像 1 Philips Norelco MultiGroom 3100 Battery  Replacement: 手順 2、 2の画像 2
    • Grip the attachment and twist it counterclockwise until you hear a click.
    • Pull the attachment up to remove it from the trimmer.
  3. Philips Norelco MultiGroom 3100 Battery  Replacement: 手順 3、 2の画像 1 Philips Norelco MultiGroom 3100 Battery  Replacement: 手順 3、 2の画像 2
    • Hold the trimmer upright so it is facing you.
    • Insert the plastic opening tool in the gap at the top of the power button.
  4. Philips Norelco MultiGroom 3100 Battery  Replacement: 手順 4、 1の画像 1
    • Apply pressure to pry off the power button.
  5. Philips Norelco MultiGroom 3100 Battery  Replacement, Casing: 手順 5、 2の画像 1 Philips Norelco MultiGroom 3100 Battery  Replacement, Casing: 手順 5、 2の画像 2
    • Insert the spudger into the bottom of the gray bezel and begin to gently pry it off.
    • Separate the bezel one clip at a time so that the clips do not break.
  6. Philips Norelco MultiGroom 3100 Battery  Replacement: 手順 6、 2の画像 1 Philips Norelco MultiGroom 3100 Battery  Replacement: 手順 6、 2の画像 2
    • Insert the spudger in the indicated hole and apply a tilting force to loosen the outer casing.
    • Pull upward on the top of the inner housing to remove it from the outer casing.
  7. Philips Norelco MultiGroom 3100 Battery  Replacement, Battery: 手順 7、 1の画像 1
    • Grab the upper casing firmly and pull to seperate from lower casing.
    • This will require some force and may separate suddenly.
  8. Philips Norelco MultiGroom 3100 Battery  Replacement: 手順 8、 1の画像 1
    • Once upper casing is removed, use plastic spudger and insert into the side tabs to free battery casing.
    • Once tabs are freed, pull battery casing from upper casing.
    • Upper casing will not separate from tab separation alone, removal will still require manipulation by hand.
  9. Philips Norelco MultiGroom 3100 Battery  Replacement: 手順 9、 1の画像 1
    • Insert plastic spudger into battery brackets individually. "Wiggle" the bracket out of place
    • Be careful to not bend bracket severely --brackets will need to fit back into place later.
  10. Philips Norelco MultiGroom 3100 Battery  Replacement: 手順 10、 1の画像 1
    • Use a soldering gun and apply heat to the battery contact tabs until solder is malleable.
    • Once solder is malleable, carefully insert a plastic spudger beneath the tab and over the battery to pry battery away from the contact tab.
    • Use proper safety equipment when operating a soldering gun, as burns can occur. Gloves and eye protection recommended.
  11. Philips Norelco MultiGroom 3100 Battery  Replacement: 手順 11、 1の画像 1
    • Once contact tabs have been removed from the battery, the battery can now be removed by hand or by use of a plastic spudger.
    • Locate new battery and prepare for soldering in next step.
  12. Philips Norelco MultiGroom 3100 Battery  Replacement: 手順 12、 1の画像 1
    • Make sure battery is safely secured and re-solder the battery contact tab onto new battery.
    • Check that contact tab is re-soldered onto the original solder.
    • Once solder is dried and cool, toggle the power switch (not the power button) to check that the device is functional.
    • Make sure solder adequately covers the contact tab so the solder will not break in the future
    • Solder with caution. Use gloves and eye protection. Solder contains lead, work in a properly ventilated area.
ゴール
15 の人々がこのガイドを完成させました。
作成者
3人の作成者と共同で作成されました。
Mahmoud
メンバー登録日: 09/05/17
101 ポイント
1ガイドが承認済み
チーム
IUPUI, Team S1-G5, Freund Fall 2017 IUPUI, Team S1-G5, Freund Fall 2017人のメンバー
IUPUI-FREUND-F17S1G5
4 メンバー
1のガイドは作成済み
10 件のコメント
Capitalize Battery in the Title
Go ahead and upload the picture of the device.
Be sure to submit to iFixit for their comments when done.
Linda Freund - 返信
Also include prerequisite guides
Linda Freund - 返信
For the Multigroom QG3380 (which I bought at Costco in Canada), there are some differences. Don’t remove the power button – not needed. Pry off the silver frame – very hard not to break some clips. It uses two 750 mAh AAA NiMH batteries (Suppo HSY-AAA0). I’ve ordered 900 mAh batteries with clips to replace these.
Brian Panhuyzen - 返信
Where did you order the replacement batteries ?
Ferdinando Anceschi -
I had mine from Japan, QG3380 too many clips broke off and indeed don’t remove the power button on that one.
alexander_binder -
コメントを追加
統計データ:
過去 24時間: 6
過去 7 日: 47
過去 30 日: 175
今までの合計 29,703
