はじめに
The battery life of this product is poor. This guide will walk you through replacing the batteries with higher quality ones - IF YOU CAN FIND THEM - I got Battery World to supply the green replacement batteries you see in this guide and they FAILED A FEW WEEKS AFTER. In the comments you can see that Modern NiMH batteries are not compatible with the original charging circuit. I think this may be true, but others have had success. People have suggested ENELOOP AAA worked. I have not tried these.. So, I'll leave this guide up for people that want to give battery replacement a try, but you have been warned: my batteries failed after a short time. I am sick of companies building rechargeable products with the intention they be thrown out every two years.
必要な工具と部品
Pushing with your thumb, pop the trimmer blade open it on its hinge.
Remove the two steel screws.
The metal clip can now be levered off using a thin screwdriver.
With the screws out and the metal bracket removed, pushing with a screwdriver, the trimmer assembly will slide out. In most cases you can also just push gently with your thumbs.
Hold the bodygroom in one hand, buttons up, foil end towards you, with your thumb on the rubber buttons.
Push forward with your thumb and the chrome plastic front panel will slide forward 3mm easily. You can now take it off.
この手順で使用する道具:iFixit Opening Picks (Set of 6)$4.99
Carefully remove the circuit board and battery assembly.
Remove the tape that holds the LED board. The LED board is taped to the battery assembly.
Using needle nose pliers, pry off the wires and metal tabs carefully.
If you're having trouble prying off the wires, you may try drilling out the welds that secure the wires. Note that it's easy to permanently damage components when drilling, so only attempt this procedure if you're confident.
Cut 5mm of heat shrink and put on wires before soldering to tabs. Use a clamp to hold the unit when soldering. Get a good join. This unit generates serious vibration and any dodgy join will soon break. Red to positive, Black to Negative.
Put the unit in charging cradle and see if it charges.
If the unit does not charge properly, the battery holder may not be making contact with the charging pins that can be seen on the sides of the unit. Ensure that the battery compartment is seated completely and that the two metal pins/arms are clean and making a solid connection.
If either the trimmer or shaver does not come on, it may be that the batteries need charging OR the metal contacts are bent causing them to not connect. Take electronics out, inspect contacts and try again.
Reassemble starting with the black cover. This pops in pretty easily if you help it bit by bit with a small screwdriver on each side as in picture.
Then put screws back.
Put on both chrome covers and slide them back into place snugly.
Slide on trimmer assembly
Put steel spring clip back on. Screw in steel screws. Pop trimmer closed and put black plastic guard back on.
140 の人々がこのガイドを完成させました。
123 件のコメント
Can I charge newly installed Eneloop batteries via the same Norelco Bodygroom charger-stand?
Absolutely! Just charge as normal.
Tim -
I replaced the stock battery with a 1000nAH battery. I believe the stock batteries were 600mAH. It runs fine, but when charging it continuously blinks. It never proceeds to a solid light & then off. I have not yet run it down completely, so I don’t know it it is charging completely.
thanks for posting this tutorial with photos. I just completed this job successfully, thanks.
jason keim - 返信
Been looking to do this for a while. Caution on the "optional" step to solder the battery tabs. They were originally spot welded to the battery so you have to somewhat mangle them to pull them off. When I tried to solder them to the new batteries, they overheated and ruptured. Be very careful.
