メインコンテンツにスキップ
Philips Norelco 5801XL Front and Back Housing Replacement
必要な工具と部品
  1. Philips Norelco 5801XL Front and Back Housing Replacement, Front and/or back housing: 手順 1、 2の画像 1 Philips Norelco 5801XL Front and Back Housing Replacement, Front and/or back housing: 手順 1、 2の画像 2
    • Remove the two T8 2 mm Phillips screws on the back housing.
  2. Philips Norelco 5801XL Front and Back Housing Replacement: 手順 2、 2の画像 1 Philips Norelco 5801XL Front and Back Housing Replacement: 手順 2、 2の画像 2
    • Separate the back housing and the front housing using the plastic opening tool.
  3. Philips Norelco 5801XL Front and Back Housing Replacement: 手順 3、 3の画像 1 Philips Norelco 5801XL Front and Back Housing Replacement: 手順 3、 3の画像 2 Philips Norelco 5801XL Front and Back Housing Replacement: 手順 3、 3の画像 3
    • Using the plastic opening tool, carefully pry the inside of the middle bracket towards the outside of the housing in order to remove it.
  4. Philips Norelco 5801XL Front and Back Housing Replacement: 手順 4、 1の画像 1
    • Remove the two T8 2 mm screws near the bottom of the device.
    • Remove the bracket the screws were holding in place.
  5. Philips Norelco 5801XL Front and Back Housing Replacement: 手順 5、 1の画像 1
    • Insert the plastic opening tool into the charging port and push inwards.
  6. Philips Norelco 5801XL Front and Back Housing Replacement: 手順 6、 1の画像 1
    • Remove the two T8 2 mm screws near the top of the device shown here.
  7. Philips Norelco 5801XL Front and Back Housing Replacement: 手順 7、 3の画像 1 Philips Norelco 5801XL Front and Back Housing Replacement: 手順 7、 3の画像 2 Philips Norelco 5801XL Front and Back Housing Replacement: 手順 7、 3の画像 3
    • Cautiously lift and twist the circuit board, then begin sliding the inside assembly forward.
    • After sliding it forward, the whole assembly will separate from the rear housing.
  8. Philips Norelco 5801XL Front and Back Housing Replacement: 手順 8、 1の画像 1
    • The housing and the inside assembly should be completely separated.
終わりに
Now, you can put the new housing on. To reassemble your device, follow these instructions in reverse order.
作成者
7人の作成者と共同で作成されました。
Ben Gibbs
メンバー登録日: 02/16/16
361 ポイント
3のガイドは作成済み
チーム
IUPUI, Team 3-2, Harley Spring 2016 IUPUI, Team 3-2, Harley Spring 2016人のメンバー
IUPUI-HARLEY-S16S3G2
4 メンバー
6のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 4
今までの合計 632
