メインコンテンツにスキップ
はじめに
Easy and budget replacement for a broken or missing bulb.
  1. Philips Hue lightbulb Bulb Replacement, Purpose: 手順 1、 3の画像 1 Philips Hue lightbulb Bulb Replacement, Purpose: 手順 1、 3の画像 2 Philips Hue lightbulb Bulb Replacement, Purpose: 手順 1、 3の画像 3
    • Philips Hue light bulbs are expensive ($30-70). The glass bulb is really thin and can be easily broken, resulting in an annoying aggressive light.
    • On the other hand, Ikea recently released budget & strong light bulbs ($6.99 for two). This guide will show you how to dismount an Ikea light bulb and how to use its bulb to fix a broken Philips Hue bulb with low budget.
  2. Philips Hue lightbulb Bulb Replacement, Screw thread contact and LED controller: 手順 2、 3の画像 1 Philips Hue lightbulb Bulb Replacement, Screw thread contact and LED controller: 手順 2、 3の画像 2 Philips Hue lightbulb Bulb Replacement, Screw thread contact and LED controller: 手順 2、 3の画像 3
    • Start by carefully removing the remaining broken glass parts from the Philips Hue lightbulb. On this example, glass parts have already been removed.
    • Then use your Groove Joint Pliers to gently crush and remove the screw thread contact of the IKEA lightbulb.
    • Once removed, you'll be able to extract the LED controller using your fingers. You might have to use a pliers again.
  3. Philips Hue lightbulb Bulb Replacement, Body removal: 手順 3、 2の画像 1 Philips Hue lightbulb Bulb Replacement, Body removal: 手順 3、 2の画像 2
    • The bulb is sealed by the plastic & metallic body.
    • Firmly use Cutting Pliers to cut and remove the body. You will only need to break the plastic layer in order to free the bulb.
  4. Philips Hue lightbulb Bulb Replacement, Installing the new bulb: 手順 4、 3の画像 1 Philips Hue lightbulb Bulb Replacement, Installing the new bulb: 手順 4、 3の画像 2 Philips Hue lightbulb Bulb Replacement, Installing the new bulb: 手順 4、 3の画像 3
    • Put glue on both the Ikea bulb and the Philips light bulb.
    • Wait a few minutes before pressing firmly against each other.
  5. Philips Hue lightbulb Bulb Replacement, Admire the magic operate: 手順 5、 1の画像 1
    • Congratulations ! You just fixed a $60 light bulb for less than $4 !
ゴール
6 の人々がこのガイドを完成させました。
Vincent Monteil
メンバー登録日: 2013年07月06日
6,835 ポイント
19のガイドは作成済み
7 件のコメント
Can't wait to try it! I really didn't want to lose this color hue bulb, so this is a great way to extend the life of these bulbs
Valerie P - 返信
You’re exactly the kind of person who is in the situation for which I posted this guide :) :) :)
fingers crossed for you !!
Vincent Monteil -
Is there any other model that fits better into the Philips Hue? I broke one and want to fix it but I see on your pictures that the Ikea bulb doesn’t fit perfectly.
maybe we can find another model that fits into the Hue base…
in any case I want to thank you for the guide! Good idea to repair Hue bulbs
Iso Box - 返信
Hi !
sorry for missing your comment !
i have no idea to be honest. This is a easy hack that worked fine for me since my bulbs are in an enclosure :)
hope you found something that worked for you !
Vincent Monteil -
Great stuff! Has anyone tried unscrewing the three screws seen on the second picture under step 1? I figure that would make it easier to get all of the broken glass out of the way and start with a clean slate before gluing the new glass on there. I just don’t know if there are any cables under there that would break or something of that nature, and don’t really want to find out if I risk breaking the entire thing.
Maybe someone with a completely dead bulb could try it and snap some pictures? Fingers crossed!
David Wiklund Jabbour - 返信
Okay, so after further research the plastic piece held down by the three crews is just a lid. It lifted up with a bit of pursuasion due to the glue/silicone mold. Do note, though, that there are different designs out there. My bulb has a star pattern LED layout. In my case lifting the lid made it easier to completely remove the shattered glass. Good luck ya’ll.
Hi David !
thanks for putting your own feedback to the guide ! I’m glad that you found a way
I personnaly had to apply extra « force » on several parts but overall removing the glass was quite easy !
good luck with the fixing process
Vincent
Vincent Monteil -
コメントを追加
統計データを表示:
過去 24時間: 17
過去 7 日: 118
過去 30 日: 381
今までの合計 17,822
