メインコンテンツにスキップ
Philips DVP642 Power Supply Replacement
必要な工具と部品
  1. Philips DVP642 Power Supply Replacement, Top Panel: 手順 1、 2の画像 1 Philips DVP642 Power Supply Replacement, Top Panel: 手順 1、 2の画像 2
    • Remove four 7.5 mm Phillips screws on the both sides (2 on each side).
    • Remove five 7.5 mm Phillips screws on the back of the player.
  2. Philips DVP642 Power Supply Replacement: 手順 2、 2の画像 1 Philips DVP642 Power Supply Replacement: 手順 2、 2の画像 2
    • Lift the top panel from the back and remove. It should come off without being forced. There is a lip near the front so you many need to slide the top panel back slightly to remove it.
  3. Philips DVP642 Power Supply Replacement, Power Supply: 手順 3、 2の画像 1 Philips DVP642 Power Supply Replacement, Power Supply: 手順 3、 2の画像 2
    • Slide the power cord out from the case.
    • Be sure not to lose the rubber clip that is wrapped around the cord.
  4. Philips DVP642 Power Supply Replacement: 手順 4、 1の画像 1
    • Remove the ribbon attached to the power supply by pushing the latch and gently pulling up.
  5. Philips DVP642 Power Supply Replacement: 手順 5、 2の画像 1 Philips DVP642 Power Supply Replacement: 手順 5、 2の画像 2
    • Now remove this ribbon wire by grasping the white head firmly and pulling up gently.
  6. Philips DVP642 Power Supply Replacement: 手順 6、 2の画像 1 Philips DVP642 Power Supply Replacement: 手順 6、 2の画像 2
    • Remove these two 7.5m Phillips screws and the matching set at the other end of the supply.
    • Now remove the ribbon that attaches the power supply to the motherboard by grasping the white head and gently pulling up.
  7. Philips DVP642 Power Supply Replacement: 手順 7、 3の画像 1 Philips DVP642 Power Supply Replacement: 手順 7、 3の画像 2 Philips DVP642 Power Supply Replacement: 手順 7、 3の画像 3
    • Remove the last screw.
    • Pinch this plastic prong and slide the power supply up and over it. The power supply should lift free.
  8. Philips DVP642 Power Supply Replacement: 手順 8、 2の画像 1 Philips DVP642 Power Supply Replacement: 手順 8、 2の画像 2
    • Your power supply is now free!
    • If the fuse circled here is blown (the small wire in the glass tube is missing or broken), remove it by pinching it tightly and pulling it straight out.
    • You can find a new fuse here.
終わりに
7 の人々がこのガイドを完成させました。
作成者
4人の作成者と共同で作成されました。
Toby Goldsteinholm
メンバー登録日: 10/09/11
360 ポイント
2のガイドは作成済み
チーム
Cal Poly, Team 21-20, Maness Fall 2011 Cal Poly, Team 21-20, Maness Fall 2011人のメンバー
CPSU-MANESS-F11S21G20
4 メンバー
7のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 8
過去 30 日: 44
今までの合計 13,330
