この修理ガイドは変更されています。最新の未承認バージョンに切り替えます。
はじめに
In this guide, we are going to detach the disc tray from the device.
必要な工具と部品
Remove four 7.5 mm Phillips screws on the both sides (2 on each side).
Remove five 7.5 mm Phillips screws on the back of the player.
Remove two 7.5 mm screws, one on each side of the player.
Remove three 7.5mm screws from the bottom of the player.
6 の人々がこのガイドを完成させました。
3 件のコメント
If you work at it, inserting a small screwdriver at appropriate places, you can get the drawer front off (do this with drawer open). This is easier than removing the front panel from the player.
I failed huhuhu
