はじめに
In this guide, we are going to detach the disc tray from the device.
必要な工具と部品
Remove four 7.5 mm Phillips screws on the both sides (2 on each side).
Remove five 7.5 mm Phillips screws on the back of the player.
Remove two 7.5 mm screws, one on each side of the player.
Remove three 7.5mm screws from the bottom of the player.
Tilt the tray sideways and then pull back gently to separate the tray from the front panel.
Alright, so after I remove it, what am I looking for? There has to be more instructions other than how to remove the disc tray. What do I do next?
6 の人々がこのガイドを完成させました。
3 件のコメント
If you work at it, inserting a small screwdriver at appropriate places, you can get the drawer front off (do this with drawer open). This is easier than removing the front panel from the player.
I failed huhuhu
When i put in a dvd the dvd player want open
I have to unplug it and plug it back in, so it
will open. If I don't put a dvd in it opens and'
closes fine. What's causing this ?
John Bailey - 返信
