メインコンテンツにスキップ
Philips DVP642 Disc Tray Replacement
必要な工具と部品
  1. Philips DVP642 Disc Tray Replacement, Top Panel: 手順 1、 2の画像 1 Philips DVP642 Disc Tray Replacement, Top Panel: 手順 1、 2の画像 2
    • Remove four 7.5 mm Phillips screws on the both sides (2 on each side).
    • Remove five 7.5 mm Phillips screws on the back of the player.
    When i put in a dvd the dvd player want open
    I have to unplug it and plug it back in, so it
    will open. If I don't put a dvd in it opens and'
    closes fine. What's causing this ?
    John Bailey - 返信
  2. Philips DVP642 Disc Tray Replacement: 手順 2、 2の画像 1 Philips DVP642 Disc Tray Replacement: 手順 2、 2の画像 2
    • Lift the top panel from the back and remove. It should come off without being forced. There is a lip near the front so you many need to slide the top panel back slightly to remove it.
  3. Philips DVP642 Disc Tray Replacement, Disc Tray: 手順 3、 2の画像 1 Philips DVP642 Disc Tray Replacement, Disc Tray: 手順 3、 2の画像 2
    • Remove two 7.5 mm screws, one on each side of the player.
    • Remove three 7.5mm screws from the bottom of the player.
    • Note that the three screws from the bottom are slightly different screws.
  4. Philips DVP642 Disc Tray Replacement: 手順 4、 1の画像 1
    • Detach all the ribbon wires (4) attached to the motherboard
  5. Philips DVP642 Disc Tray Replacement: 手順 5、 3の画像 1 Philips DVP642 Disc Tray Replacement: 手順 5、 3の画像 2 Philips DVP642 Disc Tray Replacement: 手順 5、 3の画像 3
    • The first 3 ribbon wires can be removed by grasping near the head and gently pulling up.
    • Locate the skinny fourth ribbon wire near the top right of the motherboard.
    • Remove the fourth ribbon wire by grasping both sides of the black clip and pulling up. When reinserting, pull the black clip up, insert the ribbon ribbon, and push the black clip back down.
    • Be firm, but gentle when pulling to avoid pulling the wires off the head.
  6. Philips DVP642 Disc Tray Replacement: 手順 6、 1の画像 1
    • Now remove the remaining three 7.5 mm Phillips screws that hold the disc tray to the body.
    • Remove the 12 mm Phillips screw that secures the tray to the upright metal frame.
    • Remove the two 7.5 mm Phillips screws that attach the disc tray to the motherboard and front panel.
  7. Philips DVP642 Disc Tray Replacement: 手順 7、 1の画像 1
    • Gently pull forward and upward to free disc tray.
  8. Philips DVP642 Disc Tray Replacement: 手順 8、 1の画像 1
    • Tilt the tray sideways and then pull back gently to separate the tray from the front panel.
    Alright, so after I remove it, what am I looking for? There has to be more instructions other than how to remove the disc tray. What do I do next?
    Noreen M Everitt - 返信
終わりに
6 の人々がこのガイドを完成させました。
作成者
5人の作成者と共同で作成されました。
Toby Goldsteinholm
メンバー登録日: 10/09/11
360 ポイント
2のガイドは作成済み
チーム
Cal Poly, Team 21-20, Maness Fall 2011 Cal Poly, Team 21-20, Maness Fall 2011人のメンバー
CPSU-MANESS-F11S21G20
4 メンバー
7のガイドは作成済み
3 件のコメント
If you work at it, inserting a small screwdriver at appropriate places, you can get the drawer front off (do this with drawer open). This is easier than removing the front panel from the player.
Steve Emerson - 返信
I failed huhuhu
Hello kitty - 返信
not useful without source for parts. i believe the dvd drive is a sony oem.
mapatouli - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 10
今までの合計 9,176
