メインコンテンツにスキップ
Philips BiPAP S/T Humidifier Replacement
医療機器
この修理ガイドは医療機器メーカーからの是認を得ておらず、iFixitと医療機器メーカーは提携していません。
必要な工具と部品
  1. Philips BiPAP S/T Humidifier Replacement, Humidifier: 手順 1、 1の画像 1
    • Remove the Water Chamber Assembly.
    • Gently squeeze the latch on the Flip Lid Assembly to release it.
    • Lift the Flip Lid Assembly.
    • Pull the Humidifier Tank Assembly out of the Humidifier.
  2. Philips BiPAP S/T Humidifier Replacement: 手順 2、 1の画像 1
    • Remove the Tank Top Seal from the Flip Lid Assembly.
    • If this is the source of the error, put in a new one.
  3. Philips BiPAP S/T Humidifier Replacement: 手順 3、 2の画像 1 Philips BiPAP S/T Humidifier Replacement: 手順 3、 2の画像 2
    • Remove the Dry Box Seal.
    • If this is the source of error, place this part with a new one.
    • When replacing, ensure that the narrow end of the seal is inserted into the Dry Box.
  4. Philips BiPAP S/T Humidifier Replacement: 手順 4、 2の画像 1 Philips BiPAP S/T Humidifier Replacement: 手順 4、 2の画像 2
    • Remove the Dry Box Assembly.
    • Insert a flat blade screwdriver into the hole located on the back of the Humidifier and lightly press inward to release the Dry Box Assembly.
    • Do not press firmly on the screwdriver as damage may occur.
    • Remove the Inlet Seal from the Dry Box Assembly
  5. Philips BiPAP S/T Humidifier Replacement: 手順 5、 3の画像 1 Philips BiPAP S/T Humidifier Replacement: 手順 5、 3の画像 2 Philips BiPAP S/T Humidifier Replacement: 手順 5、 3の画像 3
    • Remove the Flip Lid Assembly.
    • Use a screwdriver to push in on the latches that secure the Flip Lid Assembly to the Humidifier Top Housing.
    • Bend the Flip Lid Assembly completely backwards until it is removed.
    • For Heated Tube devices, remove the wire harness from the base.
  6. Philips BiPAP S/T Humidifier Replacement: 手順 6、 1の画像 1
    • Use a T8 Torx screwdriver to remove the four #4 x 1/2" screws that secure the Top Housing to the Humidifier Bottom Housing
  7. Philips BiPAP S/T Humidifier Replacement: 手順 7、 1の画像 1
    • Slide the Outside Cover out of the Bottom Housing.
  8. Philips BiPAP S/T Humidifier Replacement: 手順 8、 1の画像 1
    • Remove the Left Side Panel.
    • Use a T15 Torx screwdriver to remove the four #6 x 1/4" screws that secure the Bottom Housing to the Lower Base Assembly.
  9. Philips BiPAP S/T Humidifier Replacement: 手順 9、 2の画像 1 Philips BiPAP S/T Humidifier Replacement: 手順 9、 2の画像 2
    • Remove the Heater Plate Assembly.
    • The Heater Plate Assembly is secured by two small tabs.
    • Once replaced, secure the Bottom Housing to the Lower Base using the four #6 x 1/4" screws.
    • Be sure the Heater Plate Spring is properly seated under the Heater Plate.
終わりに
作成者
2人の作成者と共同で作成されました。
Courtney Huitt
メンバー登録日: 04/07/20
169 ポイント
1ガイドが承認済み
チーム
Cal Poly, Team S7-G3, Paton Spring 2020 Cal Poly, Team S7-G3, Paton Spring 2020人のメンバー
CPSU-PATON-S20S7G3
3 メンバー
3のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 9
今までの合計 409
