メインコンテンツにスキップ
Peugeot Boxer Headlamp Bulb Replacement
必要な工具と部品
  1. Peugeot Boxer Headlamp Bulb Replacement, Bonnet Catch: 手順 1、 1の画像 1
    • Open the passenger side door to find the bonnet release catch.
    • Pull the catch down and towards you to release the bonnet of the van.
  2. Peugeot Boxer Headlamp Bulb Replacement, Secondary Bonnet Catch: 手順 2、 1の画像 1
    • Once the bonnet is loosened, find the yellow handle of the secondary bonnet catch by feeling underneath
    • Once you locate the catch, push the bonnet catch upwards, this will release the bonnet
  3. Peugeot Boxer Headlamp Bulb Replacement, Open Bonnet: 手順 3、 1の画像 1
    • Use the strut, located to the right of the hood to prop open the bonnet.
    • Make sure the strut is secure to the hood! If the strut comes down, this may damage your car and strut!
  4. Peugeot Boxer Headlamp Bulb Replacement, Torx Bolts: 手順 4、 2の画像 1 Peugeot Boxer Headlamp Bulb Replacement, Torx Bolts: 手順 4、 2の画像 2
    • Remove the two Torx bolts holding the headlamp assembly at each corner.
  5. Peugeot Boxer Headlamp Bulb Replacement, Slide Headlamp Out: 手順 5、 1の画像 1
    • Gently slide headlamp assembly out
    • Make sure to move the headlight diagonally towards you and towards the centre of the vehicle
  6. Peugeot Boxer Headlamp Bulb Replacement, Rubber Cap: 手順 6、 2の画像 1 Peugeot Boxer Headlamp Bulb Replacement, Rubber Cap: 手順 6、 2の画像 2
    • Pull the tab on rubber cap, revealing the back of the headlamp bulb.
  7. Peugeot Boxer Headlamp Bulb Replacement, Disconnect Bulb: 手順 7、 1の画像 1
    • Remove the electrical connection from the old bulb (it should just pull off).
    • Make a note of which way up the plug was for when you connect everything back up again.
  8. Peugeot Boxer Headlamp Bulb Replacement, Remove Bulb: 手順 8、 1の画像 1
    • With needle-nosed pliers, carefully 'wiggle' the old bulb out from its housing.
  9. Peugeot Boxer Headlamp Bulb Replacement, New Bulb: 手順 9、 1の画像 1
    • Locate your new bulb. Taking care to make sure it is the right way up, push it firmly into place until you feel it clip in.
終わりに
6 の人々がこのガイドを完成させました。
作成者
3人の作成者と共同で作成されました。
Kit Marsden
メンバー登録日: 05/04/21
520 ポイント
2のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 13
過去 7 日: 84
過去 30 日: 316
今までの合計 5,843
