メインコンテンツにスキップ
Petzl E03 050 Headlamp Light Bulb Replacement Guide
  1. Petzl E03 050 Headlamp Light Bulb Replacement Guide, Check For Spare Bulb: 手順 1、 1の画像 1
    • Check for a spare bulb in the spare bulb compartment located on the back of the battery housing (found behind the mount assembly). If no spare bulb is found in the spare bulb compartment you will need to purchase a replacement 3V incandescent bulb from a reputable retailer
  2. Petzl E03 050 Headlamp Light Bulb Replacement Guide, Loosen the Lens Piece: 手順 2、 1の画像 1
    • Turn the lens piece counterclockwise (left) until it is fully extended.
  3. Petzl E03 050 Headlamp Light Bulb Replacement Guide, Remove the Lens Piece: 手順 3、 1の画像 1
    • Remove the lens piece by firmly pulling it away from the battery housing.
  4. Petzl E03 050 Headlamp Light Bulb Replacement Guide, Remove the Lightbulb: 手順 4、 1の画像 1
    • Turn the bulb counterclockwise (left) until it becomes free. Safely discard the old bulb.
  5. Petzl E03 050 Headlamp Light Bulb Replacement Guide, Install the New Lightbulb: 手順 5、 1の画像 1
    • Install the new bulb by inserting it into the socket.
  6. Petzl E03 050 Headlamp Light Bulb Replacement Guide, Rotate Replacement Light Bulb: 手順 6、 1の画像 1
    • Rotate the bulb clockwise (right) until it is firmly fixed in place.
  7. Petzl E03 050 Headlamp Light Bulb Replacement Guide, Re-attach the Lens Piece: 手順 7、 1の画像 1
    • Press the lens piece onto the front of the battery housing.
  8. Petzl E03 050 Headlamp Light Bulb Replacement Guide, Tighten the Lens Piece: 手順 8、 1の画像 1
    • Turn the lens piece clockwise (right) to the “On” position. If the light fails to illuminate after turning the lens piece to the “On” position you may have to replace the batteries.
ゴール
作成者
2人の作成者と共同で作成されました。
Carla
メンバー登録日: 10/19/14
131 ポイント
1ガイドが承認済み
チーム
Baylor, Team 8-10, Williams Fall 2014 Baylor, Team 8-10, Williams Fall 2014人のメンバー
BU-WILLIAMS-F14S8G10
3 メンバー
10のガイドは作成済み
3件のガイドコメント
Ha I wonder how many people don’t even realize there’s a replacement readily available on their head! Thanks for sharing.
jmania - 返信
This was my father headlamp. Want to continue using it.. makes me feel like he is this with me
laura.odonnell52 - 返信
Is it also possible to replace the old 3v light bulb with an LED light?
bertkling - 返信
コメントを追加
統計データ:
過去 24時間: 4
過去 7 日: 15
過去 30 日: 95
今までの合計 5,968
