メインコンテンツにスキップ
修理を始めるには
修理する権利
パーツ&ツール
はじめに
The SmartFeeder has a rubber wheel between the top food basin and the lower metal tray. This wheel may become stuck or damaged during operation. Get a friend to help you hold the wheel housing open while you remove the wheel in Step 4.
パーツ
パーツは指定されていません。
  1. Eject the SmartBowl by pressing the button located at the front of the SmartFeeder base. Eject the SmartBowl by pressing the button located at the front of the SmartFeeder base. Eject the SmartBowl by pressing the button located at the front of the SmartFeeder base.
    • Eject the SmartBowl by pressing the button located at the front of the SmartFeeder base.
  2. Remove the food tub by twisting it counter-clockwise with both hands and lifting it up. Remove the food tub by twisting it counter-clockwise with both hands and lifting it up. Remove the food tub by twisting it counter-clockwise with both hands and lifting it up.
    • Remove the food tub by twisting it counter-clockwise with both hands and lifting it up.
  3. Remove the black plastic gasket from the top of the SmartFeeder by placing your fingers on the side of it and lifting up.
    • Remove the black plastic gasket from the top of the SmartFeeder by placing your fingers on the side of it and lifting up.
    • It should come off very easily.
  4. iPhone LCDスクリーン修理キット
    生涯保証付きの低コストオプション
    キット商品を見る
    品質ではなく、修理コストを削減しましょう。
    キット商品を見る
  5. Flip over the SmartFeeder by using both hands. Partially open the outer case of the SmartFeeder by wedging an iFixit Opening Tool on each side. Partially open the outer case of the SmartFeeder by wedging an iFixit Opening Tool on each side.
    • Flip over the SmartFeeder by using both hands.
    • Partially open the outer case of the SmartFeeder by wedging an iFixit Opening Tool on each side.
  6. Turn the SmartFeeder on its side and with one hand on the base, carefully pull out the central section. Place the bottom piece of the device right-side up.
    • Turn the SmartFeeder on its side and with one hand on the base, carefully pull out the central section.
    • Place the bottom piece of the device right-side up.
  7. Remove the eight 11mm screws from the central pillar using  a Phillips #1 screwdriver.
    • Remove the eight 11mm screws from the central pillar using a Phillips #1 screwdriver.
  8. Pull apart the two sides of the central pillar at the top by using both hands. The two sides will not completely separate at the base.
    • Pull apart the two sides of the central pillar at the top by using both hands.
    • The two sides will not completely separate at the base.
    • With the two halves partially separated, pull out the rubber wheel with your hand.
    • A small black rectangular piece may fall out of the chute when the halves are partially separated. Reattach this by reaching into the chute and putting the pins from the piece into the holes on the side of the chute.
終わりに
ある他の人がこのガイドを完成しました。
Louis Squitieri
メンバー登録日: 2018年10月08日
157 ポイント
1ガイドが承認済み
チーム
Cal Poly, Team S13-G7, White Fall 2018 Cal Poly, Team S13-G7, White Fall 2018人のメンバー
CPSU-WHITE-F18S13G7
4 メンバー
5のガイドは作成済み
コメント1件
Always nice to have a link to part so we know where to buy
David - 返信
コメントを追加
統計データを表示:
過去 24時間: 0
過去 7 日: 5
過去 30 日: 33
今までの合計 728
