メインコンテンツにスキップ
Petnet SmartFeeder SF10E Charging Assembly Replacement
必要な工具と部品
  1. Petnet SmartFeeder SF10E Charging Assembly Replacement, Battery: 手順 1、 3の画像 1 Petnet SmartFeeder SF10E Charging Assembly Replacement, Battery: 手順 1、 3の画像 2 Petnet SmartFeeder SF10E Charging Assembly Replacement, Battery: 手順 1、 3の画像 3
    • Eject the SmartBowl by pressing the button located at the front of the SmartFeeder base.
    • Remove the metal tray by using both hands and pulling out the bowl towards you.
  2. Petnet SmartFeeder SF10E Charging Assembly Replacement: 手順 2、 2の画像 1 Petnet SmartFeeder SF10E Charging Assembly Replacement: 手順 2、 2の画像 2
    • Turn the bowl tray side down by using both hands.
    • Remove seven 11 mm screws by using the Phillips #1 screwdriver.
  3. Petnet SmartFeeder SF10E Charging Assembly Replacement: 手順 3、 2の画像 1 Petnet SmartFeeder SF10E Charging Assembly Replacement: 手順 3、 2の画像 2
    この手順で使用する道具:
    購入する
    • Take the battery out of the SmartBowl with tweezers, avoid pulling on any wires.
    • Hold the SmartBowl down using one hand while using the other hand to remove the battery.
  4. Petnet SmartFeeder SF10E Charging Assembly Replacement: 手順 4、 2の画像 1 Petnet SmartFeeder SF10E Charging Assembly Replacement: 手順 4、 2の画像 2
    • Remove the tape, closest to the four white connectors, with your hands.
    • Keep the wires attached to the tape for easy reassembly.
  5. Petnet SmartFeeder SF10E Charging Assembly Replacement: 手順 5、 2の画像 1 Petnet SmartFeeder SF10E Charging Assembly Replacement: 手順 5、 2の画像 2
    • Trace the wires with your hands from the battery to the motherboard.
    • Detach the three-prong connector between the battery and the motherboard by pulling the white connectors with your hands.
    • Hold on to the sockets on the motherboard or you could accidentally pull off the entire assembly.
  6. Petnet SmartFeeder SF10E Charging Assembly Replacement, Motherboard: 手順 6、 1の画像 1
    • Remove the remaining 3-prong connectors by carefully pulling outwards.
  7. Petnet SmartFeeder SF10E Charging Assembly Replacement: 手順 7、 2の画像 1 Petnet SmartFeeder SF10E Charging Assembly Replacement: 手順 7、 2の画像 2
    • Push both small gray pieces next to the ribbon connector towards the ribbon to put them in the “open” position using the nylon spudger.
  8. Petnet SmartFeeder SF10E Charging Assembly Replacement: 手順 8、 2の画像 1 Petnet SmartFeeder SF10E Charging Assembly Replacement: 手順 8、 2の画像 2
    • Remove the ribbon connector from its slot by pulling on it with a couple fingers.
    • The ribbon should come out easily with the gray pieces in the "open" position. Do not use too much force with the ribbon or it could be damaged.
    • Make sure the gray pieces are in the “open” position when you reassemble the ribbon connector or the connector will not go into its slot. Once the connector is in the slot, slide the gray tabs back down into the “closed” position
  9. Petnet SmartFeeder SF10E Charging Assembly Replacement, Charging Assembly: 手順 9、 2の画像 1 Petnet SmartFeeder SF10E Charging Assembly Replacement, Charging Assembly: 手順 9、 2の画像 2
    • Use the nylon spudger to remove the charging assembly from the SmartBowl.
  10. Petnet SmartFeeder SF10E Charging Assembly Replacement: 手順 10、 2の画像 1 Petnet SmartFeeder SF10E Charging Assembly Replacement: 手順 10、 2の画像 2
    • Push the small gray pieces on the ribbon connector into the “open” position with the nylon spudger.
    • Do not to use too much force when removing the ribbon or any of the electrical components because they are sensitive and delicate.
  11. Petnet SmartFeeder SF10E Charging Assembly Replacement: 手順 11、 2の画像 1 Petnet SmartFeeder SF10E Charging Assembly Replacement: 手順 11、 2の画像 2
    • Pull the ribbon connector out of its slot using one hand and another hand on the base of the charging assembly.
終わりに
作成者
3人の作成者と共同で作成されました。
Kristin Villanueva
メンバー登録日: 10/08/18
370 ポイント
2のガイドは作成済み
チーム
Cal Poly, Team S13-G7, White Fall 2018 Cal Poly, Team S13-G7, White Fall 2018人のメンバー
CPSU-WHITE-F18S13G7
4 メンバー
5のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 14
今までの合計 273
