メインコンテンツにスキップ
Petnet SmartFeeder SF10E 12 Pin Connector Replacement
必要な工具と部品
  1. Petnet SmartFeeder SF10E 12 Pin Connector Replacement, 12 Pin Connector: 手順 1、 3の画像 1 Petnet SmartFeeder SF10E 12 Pin Connector Replacement, 12 Pin Connector: 手順 1、 3の画像 2 Petnet SmartFeeder SF10E 12 Pin Connector Replacement, 12 Pin Connector: 手順 1、 3の画像 3
    • Eject the SmartBowl by pressing the button located at the front of the SmartFeeder base.
  2. Petnet SmartFeeder SF10E 12 Pin Connector Replacement: 手順 2、 3の画像 1 Petnet SmartFeeder SF10E 12 Pin Connector Replacement: 手順 2、 3の画像 2 Petnet SmartFeeder SF10E 12 Pin Connector Replacement: 手順 2、 3の画像 3
    • Remove the food tub by twisting it counter-clockwise with both hands and lifting it up.
  3. Petnet SmartFeeder SF10E 12 Pin Connector Replacement: 手順 3、 1の画像 1
    • Remove the black plastic gasket from the top of the SmartFeeder by placing your fingers on the side of it and lifting up.
    • It should come off easily.
  4. Petnet SmartFeeder SF10E 12 Pin Connector Replacement: 手順 4、 1の画像 1
    • Flip over the SmartFeeder by using both hands.
    • Partially open the outer case of the SmartFeeder by wedging an iFixit Opening Tool on each side.
  5. Petnet SmartFeeder SF10E 12 Pin Connector Replacement: 手順 5、 2の画像 1 Petnet SmartFeeder SF10E 12 Pin Connector Replacement: 手順 5、 2の画像 2
    • Turn the SmartFeeder on its side and with one hand on the base, carefully pull out the central section.
    • Place the bottom piece of the device right-side up.
  6. Petnet SmartFeeder SF10E 12 Pin Connector Replacement: 手順 6、 2の画像 1 Petnet SmartFeeder SF10E 12 Pin Connector Replacement: 手順 6、 2の画像 2
    • Remove one 10 mm screw by using the Phillips #1 screwdriver.
    • Remove the plastic retaining piece for the daughterboard by pulling it out with one hand.
  7. Petnet SmartFeeder SF10E 12 Pin Connector Replacement: 手順 7、 3の画像 1 Petnet SmartFeeder SF10E 12 Pin Connector Replacement: 手順 7、 3の画像 2 Petnet SmartFeeder SF10E 12 Pin Connector Replacement: 手順 7、 3の画像 3
    • Pull the daughterboard out of the device and remove the three-prong connectors by using your hands.
    • Hold onto the sockets on the motherboard or you could accidentally pull off the entire assembly.
終わりに
作成者
3人の作成者と共同で作成されました。
Ashley Kim
メンバー登録日: 10/08/18
187 ポイント
1ガイドが承認済み
チーム
Cal Poly, Team S13-G7, White Fall 2018 Cal Poly, Team S13-G7, White Fall 2018人のメンバー
CPSU-WHITE-F18S13G7
4 メンバー
5のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 4
今までの合計 317
