メインコンテンツにスキップ
Petmate 29027 Fountain Lid and Pump Replacement
必要な工具と部品
  1. Petmate 29027 Fountain Lid and Pump Replacement, Fountain Lid and Pump: 手順 1、 3の画像 1 Petmate 29027 Fountain Lid and Pump Replacement, Fountain Lid and Pump: 手順 1、 3の画像 2 Petmate 29027 Fountain Lid and Pump Replacement, Fountain Lid and Pump: 手順 1、 3の画像 3
    • Unplug the fountain from the electrical source and disconnect the inline plug.
    • Remove the lid.
    • Empty water from the fountain
    • Reach in the bowl and lift up the pump.
  2. Petmate 29027 Fountain Lid and Pump Replacement: 手順 2、 3の画像 1 Petmate 29027 Fountain Lid and Pump Replacement: 手順 2、 3の画像 2 Petmate 29027 Fountain Lid and Pump Replacement: 手順 2、 3の画像 3
    • Unclip the lid and intake plate using a fingernail.
  3. Petmate 29027 Fountain Lid and Pump Replacement: 手順 3、 2の画像 1 Petmate 29027 Fountain Lid and Pump Replacement: 手順 3、 2の画像 2
    • Pry out the impeller (4 white bladed propellers) which is held in place magnetically.
    • You can use a fingernail or small needle nose pliers to get under the plastic blade and lift it out.
  4. Petmate 29027 Fountain Lid and Pump Replacement: 手順 4、 3の画像 1 Petmate 29027 Fountain Lid and Pump Replacement: 手順 4、 3の画像 2 Petmate 29027 Fountain Lid and Pump Replacement: 手順 4、 3の画像 3
    • Clean the parts with warm soapy water and reassemble them.
    • Be sure to rinse thoroughly with fresh water.
    • Cleaning the motor with white vinegar (150ml) can increase disinfecting and hard water removal.
  5. Petmate 29027 Fountain Lid and Pump Replacement: 手順 5、 2の画像 1 Petmate 29027 Fountain Lid and Pump Replacement: 手順 5、 2の画像 2
    • Replace the pump into the original location.
    • Press down on the pump to engage the suction cups.
    • Place the fountain lid in the right place.
  6. Petmate 29027 Fountain Lid and Pump Replacement: 手順 6、 2の画像 1 Petmate 29027 Fountain Lid and Pump Replacement: 手順 6、 2の画像 2
    • Replug the fountain into electricity.
    • Add water as needed.
    • Never let the water level fall lower than the min fill line.
ゴール
作成者
1人の作成者と共同作成されました。
Shidie Ren
メンバー登録日: 05/11/20
133 ポイント
1ガイドが承認済み
チーム
York University, Team S1-G22, O'Regan Summer 2020 York University, Team S1-G22, O'Regan Summer 2020人のメンバー
YORK-O'REGAN-SU20S1G22
1 メンバー
1のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 10
今までの合計 527
