メインコンテンツにスキップ
Pentax PZ-10 Back Cover Locking Switch Spring Replacement
必要な工具と部品
  1. Pentax PZ-10 Back Cover Locking Switch Spring Replacement, Removing the Bottom Cover: 手順 1、 1の画像 1
    • With the lens face up and the bottom panel of the camera facing you, remove the two 7mm screws on the left using the J0 screwdriver.
    • Remove the six 4.3mm screws in the middle and right of the panel using the J0 screwdriver.
    • Pull off the bottom casing to remove.
  2. Pentax PZ-10 Back Cover Locking Switch Spring Replacement, Removing Bottom Casing: 手順 2、 1の画像 1
    • With the screws removed, the bottom casing should come off very easily by pulling on the casing.
  3. Pentax PZ-10 Back Cover Locking Switch Spring Replacement, Removing the Back Cover: 手順 3、 1の画像 1
    • Place the camera on its side so the lens is facing left.
    • Press down on the locking switch on the side panel facing you.
  4. Pentax PZ-10 Back Cover Locking Switch Spring Replacement: 手順 4、 1の画像 1
    • With the door unlocked, rotate the device to access the bottom.
  5. Pentax PZ-10 Back Cover Locking Switch Spring Replacement: 手順 5、 1の画像 1
    • Using a pair of tweezers, gently remove the metal tab securing the back door axle.
    • The door will come loose at this point, watch for any loose parts that may also come out.
  6. Pentax PZ-10 Back Cover Locking Switch Spring Replacement, Removing the Side Panel: 手順 6、 1の画像 1
    • Once the back cover is fully removed, remove the two 4.35mm screws attaching the cover of the unlocking switch, and remove the plate.
  7. Pentax PZ-10 Back Cover Locking Switch Spring Replacement, Removing the Spring: 手順 7、 1の画像 1
    • Locate the spring at the upper left corner of the face, and pull the rings of the spring off of the pins to remove it using plastic opening tools.
    • You are now ready to replace the spring.
終わりに
ある他の人がこのガイドを完成しました。
作成者
5人の作成者と共同で作成されました。
Ryan Su
メンバー登録日: 04/20/15
107 ポイント
1ガイドが承認済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 3
今までの合計 414
