メインコンテンツにスキップ
Pentax Optio WG-3 GPS Motherboard Replacement
必要な工具と部品
  1. Pentax Optio WG-3 GPS Motherboard Replacement, Motherboard: 手順 1、 1の画像 1
    • Turn over the camera so the screen is facing up.
    • Remove the four 5 mm Phillips #000 screws that secure the outer cover.
  2. Pentax Optio WG-3 GPS Motherboard Replacement: 手順 2、 1の画像 1
    • Flip over the camera so the bottom is facing up.
    • Use the Phillips PH0005 again to remove one more 5mm screw.
    • Remove the cover.
  3. Pentax Optio WG-3 GPS Motherboard Replacement: 手順 3、 1の画像 1
    • Remove the eight 5 mm Phillips #000 screws holding the circuitry together.
  4. Pentax Optio WG-3 GPS Motherboard Replacement: 手順 4、 1の画像 1
    • Carefully remove the circuitry.
  5. Pentax Optio WG-3 GPS Motherboard Replacement: 手順 5、 1の画像 1
    • There is a large silver sticker on top of the motherboard, gently remove it off of the motherboard.
  6. Pentax Optio WG-3 GPS Motherboard Replacement: 手順 6、 1の画像 1
    • Gently use the spudger set to lift open the clamps that are holding the orange ribbons down.
    • Pull out the ribbons and remove the motherboard from the body of the camera.
  7. Pentax Optio WG-3 GPS Motherboard Replacement: 手順 7、 1の画像 1
    • Remove the battery on the back of the motherboard.
  8. Pentax Optio WG-3 GPS Motherboard Replacement: 手順 8、 1の画像 1
    • Unscrew and remove one 2 mm Phillips #00 screw to remove the flash component on the top of the circuitry.
  9. Pentax Optio WG-3 GPS Motherboard Replacement: 手順 9、 1の画像 1
    • Remove three 5 mm Phillips #000 screws from the left side of the motherboard.
  10. Pentax Optio WG-3 GPS Motherboard Replacement: 手順 10、 1の画像 1
    • Remove two ribbon cables from the small circuit.
    • Remove the ribbon cable that holds the sensor to the motherboard.
  11. Pentax Optio WG-3 GPS Motherboard Replacement: 手順 11、 1の画像 1
    • The sensor is ready to be pulled out, carefully remove the sensor.
  12. Pentax Optio WG-3 GPS Motherboard Replacement: 手順 12、 1の画像 1
    • Unscrew and remove three 5 mm screws from the front panel of the battery compartment.
  13. Pentax Optio WG-3 GPS Motherboard Replacement: 手順 13、 1の画像 1
    • Pull the black panel away from the front panel.
  14. Pentax Optio WG-3 GPS Motherboard Replacement: 手順 14、 1の画像 1
    • At the top of the circuit board there are three soldered dots that need to be unsoldered to remove the back of the battery component from the motherboard.
    • The motherboard can now be pulled and replaced.
終わりに
作成者
2人の作成者と共同で作成されました。
Garrett Rose
メンバー登録日: 03/31/22
373 ポイント
2のガイドは作成済み
チーム
IUPUI, Team 3-1, Harley Spring 2022 IUPUI, Team 3-1, Harley Spring 2022人のメンバー
IUPUI-HARLEY-S22S3G1
3 メンバー
3のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 18
今までの合計 237
