はじめに
The Pentax Optio WG-2 uses SD memory cards. If your screen is not displaying anything, a faulty memory card may be the issue. Use this guide to replace the memory card of your Pentax Optio WG-2.
Press the lock lever (small tab) in an upward direction towards the word open.
Slide the cover away from the camera.
Lift the cover up to gain access to the memory card.
ある他の人がこのガイドを完成しました。
