メインコンテンツにスキップ
Pebble Time Round Battery Replacement
必要な工具と部品
  1. Pebble Time Round Battery Replacement, Glass Screen Protector: 手順 1、 1の画像 1
    • Wedge an opening tool between the case of the watch, and the glass screen bezel.
    • Pry the screen bezel away from the device.
    • If you have a difficult time getting the front bezel to separate from the case, try warming the watch up with a hair dryer.
    • There are three very tiny springs that are compressed between holes in the case and the front bezel. They can pop out once the bezel is removed, so don't lose them! Remove them and put them somewhere safe once the bezel is removed.
  2. Pebble Time Round Battery Replacement: 手順 2、 1の画像 1
    • Pull the screen protector away from the device, breaking glue sealant.
    • Separate the screen protector from the screen.
    • To re-seal the glass protector's glue, simply heat the glue.
  3. Pebble Time Round Battery Replacement, E-Paper Display: 手順 3、 1の画像 1
    • Insert a prying tool between the bezel ring and the e-paper screen. Move the tool around the circumference of the ring until it separates from the e-paper screen.
  4. Pebble Time Round Battery Replacement: 手順 4、 2の画像 1 Pebble Time Round Battery Replacement: 手順 4、 2の画像 2
    この手順で使用する道具:
    • Slightly lift the screen and you will see a yellow cable that connects to the motherboard.
    • Use a pair of tweezers to carefully pull the cable up from the motherboard to disconnect it.
  5. Pebble Time Round Battery Replacement: 手順 5、 1の画像 1
    • Use tweezers to disconnect the small yellow wire from the top of the e-paper screen.
    • The wire is connected with a bit of glue, so it will come off with ease.
  6. Pebble Time Round Battery Replacement, Motherboard: 手順 6、 1の画像 1
    • Remove the three screws that hold the motherboard down using a Phillips #000 screwdriver.
  7. Pebble Time Round Battery Replacement: 手順 7、 1の画像 1
    • Remove the cable connecting the motherboard vibration motor, microphone, and light sensor.
    • Remove the motherboard from the device.
  8. Pebble Time Round Battery Replacement, Battery: 手順 8、 1の画像 1
    • Use the small plastic iFixit opening tool from to lift the battery out of the device.
  9. Pebble Time Round Battery Replacement: 手順 9、 1の画像 1
    • Remove the battery from the watch.
終わりに
8 の人々がこのガイドを完成させました。
作成者
2人の作成者と共同で作成されました。
Will Tourinho
メンバー登録日: 10/28/21
269 ポイント
1ガイドが承認済み
チーム
UMass Dartmouth, Team 4-5, Gulbrandsen Fall 2021 UMass Dartmouth, Team 4-5, Gulbrandsen Fall 2021人のメンバー
UMASSD-GULBRANDSEN-F21S4G5
4 メンバー
5のガイドは作成済み
4件のガイドコメント
Worked great. Was able to fully remove the battery from my wife’s original dead Pebble Round. I did lose one of the tiny springs cause man those things are tiny and springy…
Daniel Houghtaling - 返信
Great guide! Very detailed and informative. Here is a replacement battery for the Pebble Time Round:
Pebble Time Round Battery SP301618AE
It comes with all the necessary tools and carries a 1 year replacement warranty!
Mike - 返信
Battery problem 😞
NAVNEET JAAT. PAPA - 返信
I have followed each of these steps but my watch will not take a charge. It boots to a screen with a plug pointing to lightning and won’t display anything else. Have I done something wrong when reconnecting the battery or is the battery not viable?
Jeff Gorvette - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 22
過去 30 日: 127
今までの合計 5,253
