はじめに
Bring back to life your Parrot FLYPAD with a brand new battery.
This guide will assist you to correctly dismantle the controller, so that you may easily replace the battery. To prevent any loss of screws, it is important to utilize a magnetic mat placed under the controller.
必要な工具と部品
Use a T6 screwdriver to remove the six screws from the back of the controller: four 0.9 mm screws and two 0.1 mm screws.
ある他の人がこのガイドを完成しました。
