はじめに
This guide will show the steps needed to remove the EPP (Expanded Polypropylene) or Styrofoam Nose. The Styrofoam nose protects the motherboard and the GPS Module. In order to remove the Nose, the battery will have to be removed first.
必要な工具と部品
Remove the two 7mm T5 torx screws using a screwdriver. There is one located on each side.
もう少しです!
To reassemble your device, follow these intructions in reverse order
終わりに
2 の人々がこのガイドを完成させました。
