はじめに
Use this guide to diagnose and replace a faulty motor on your Parrot AR.Drone 2.0.
AR.Drone 2.0 spare parts and mounting tools are available from several Parrot retailers.
必要な工具と部品
ビデオの概要
Disconnect the battery by pulling the two red wires apart.
Remove the battery by releasing the battery retaining straps.
Are you referring to the clips in step three? If so, i highly recommend a hard, flat edged tool like a plastic spudger or flat head screw driver. Push is against the opposite side of the C clip that is opened with roughly the same force you applied to get it off. You have to be really careful that you push it directly horizontal or else you might damage the shaft or risk loosing the clip if it pops off.
5 の人々がこのガイドを完成させました。
2 件のコメント
I need to know this also. replaced cross.member but did not put motors in original spots now my drone goes crazy and erratic
