メインコンテンツにスキップ
Parrot AR.Drone 2.0 Motor Replacement
必要な工具と部品
ビデオの概要
  1. Parrot AR.Drone 2.0 Motor Replacement, Propeller and Gear: 手順 1、 2の画像 1 Parrot AR.Drone 2.0 Motor Replacement, Propeller and Gear: 手順 1、 2の画像 2
    • Remove the foam body.
  2. Parrot AR.Drone 2.0 Motor Replacement: 手順 2、 2の画像 1 Parrot AR.Drone 2.0 Motor Replacement: 手順 2、 2の画像 2
    • Disconnect the battery by pulling the two red wires apart.
    • Remove the battery by releasing the battery retaining straps.
    how do i put the clips back in?
    kuki vier - 返信
    Are you referring to the clips in step three? If so, i highly recommend a hard, flat edged tool like a plastic spudger or flat head screw driver. Push is against the opposite side of the C clip that is opened with roughly the same force you applied to get it off. You have to be really careful that you push it directly horizontal or else you might damage the shaft or risk loosing the clip if it pops off.
    David Hoyt -
  3. Parrot AR.Drone 2.0 Motor Replacement: 手順 3、 1の画像 1
    • Remove the small retaining clip using a plastic opening tool.
    • Be careful as these clips can fly off and can be difficult to find.
  4. Parrot AR.Drone 2.0 Motor Replacement: 手順 4、 3の画像 1 Parrot AR.Drone 2.0 Motor Replacement: 手順 4、 3の画像 2 Parrot AR.Drone 2.0 Motor Replacement: 手順 4、 3の画像 3
    • The propeller, gear, and rod can be removed by simply lifting them off the motor.
  5. Parrot AR.Drone 2.0 Motor Replacement, Motor: 手順 5、 2の画像 1 Parrot AR.Drone 2.0 Motor Replacement, Motor: 手順 5、 2の画像 2
    • Disconnect the connector at the bottom of the motor assembly.
  6. Parrot AR.Drone 2.0 Motor Replacement: 手順 6、 1の画像 1
    • Remove the three 5mm screws on the top of the motor assembly with a PH00 bit.
  7. Parrot AR.Drone 2.0 Motor Replacement: 手順 7、 1の画像 1
    • Remove the three 5mm screws on the bottom again using a PH00 bit.
    • The three screws from the top are different from the three screws on the bottom.
  8. Parrot AR.Drone 2.0 Motor Replacement: 手順 8、 2の画像 1 Parrot AR.Drone 2.0 Motor Replacement: 手順 8、 2の画像 2
    • Carefully wiggle out the motor assembly out of the arm.
終わりに
5 の人々がこのガイドを完成させました。
作成者
10人の作成者と共同で作成されました。
David Hoyt
メンバー登録日: 04/09/10
4,023 ポイント
43のガイドは作成済み
チーム
Cal Poly, Team 25-89, Amido Spring 2010 Cal Poly, Team 25-89, Amido Spring 2010人のメンバー
CPSU-AMIDO-S10S25G89
4 メンバー
63のガイドは作成済み
2 件のコメント
are the motors different on each side?
dbksoft - 返信
I need to know this also. replaced cross.member but did not put motors in original spots now my drone goes crazy and erratic
Steven Maloney -
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 5
過去 30 日: 12
今までの合計 5,687
