メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Pantech Matrix Volume Button Replacement
必要な工具と部品
  1. Pantech Matrix Volume Button Replacement, Phone Orientation: 手順 1、 1の画像 1
    • Place phone with screen side facing toward you.
  2. Pantech Matrix Volume Button Replacement, Phone Orientation: 手順 2、 1の画像 1
    • Flip phone over so screen side is now facing down.
  3. Pantech Matrix Volume Button Replacement, Remove Back Cover: 手順 3、 2の画像 1 Pantech Matrix Volume Button Replacement, Remove Back Cover: 手順 3、 2の画像 2
    • Gently slide the backside phone cover off exposing the battery underneath.
  4. Pantech Matrix Volume Button Replacement, Lift Battery: 手順 4、 1の画像 1
    • Carefully lift the battery up from where the spudger is pointed.
  5. Pantech Matrix Volume Button Replacement, Remove Battery: 手順 5、 1の画像 1
    • Remove the battery from its dock.
  6. Pantech Matrix Volume Button Replacement, Slide SIM Card Out: 手順 6、 3の画像 1 Pantech Matrix Volume Button Replacement, Slide SIM Card Out: 手順 6、 3の画像 2 Pantech Matrix Volume Button Replacement, Slide SIM Card Out: 手順 6、 3の画像 3
    • Slide the SIM Card out of its dock.
  7. Pantech Matrix Volume Button Replacement, Remove Phone Screws: 手順 7、 2の画像 1 Pantech Matrix Volume Button Replacement, Remove Phone Screws: 手順 7、 2の画像 2
    • Use a PH000 screwdriver to remove the four 2 mm screws from each corner of the device.
  8. Pantech Matrix Volume Button Replacement, Remove Phone Casing: 手順 8、 2の画像 1 Pantech Matrix Volume Button Replacement, Remove Phone Casing: 手順 8、 2の画像 2
    • Rotate the phone so the base is facing you.
    • Use spudger to separate phone casing and inside as shown.
    • Remove the casing carefully and set aside.
  9. Pantech Matrix Volume Button Replacement, Remove Camera Screws: 手順 9、 2の画像 1 Pantech Matrix Volume Button Replacement, Remove Camera Screws: 手順 9、 2の画像 2
    • Place phone with exposed motherboard facing you.
    • Use a PH000 screwdriver to remove the five 2 mm screws holding the camera in place.
  10. Pantech Matrix Volume Button Replacement, Remove Motherboard: 手順 10、 1の画像 1
    • Carefully lift up the motherboard to expose the volume button.
  11. Pantech Matrix Volume Button Replacement, Remove Volume Button: 手順 11、 2の画像 1 Pantech Matrix Volume Button Replacement, Remove Volume Button: 手順 11、 2の画像 2
    この手順で使用する道具:
    • After moving the motherboard out of the way, locate the volume button.
    • Grasp the volume button with tweezers and pull gently to remove.
終わりに
作成者
4人の作成者と共同で作成されました。
Zeel Patel
メンバー登録日: 10/13/14
1,096 ポイント
9のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 12
過去 30 日: 39
今までの合計 287
