メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Pantech Matrix Camera Button Replacement
必要な工具と部品
  1. Pantech Matrix Camera Button Replacement, Phone Orientation: 手順 1、 1の画像 1
    • Place phone with screen side facing toward you.
  2. Pantech Matrix Camera Button Replacement, Phone Orientation: 手順 2、 1の画像 1
    • Flip phone over so screen side is now facing down.
  3. Pantech Matrix Camera Button Replacement, Remove Back Cover: 手順 3、 2の画像 1 Pantech Matrix Camera Button Replacement, Remove Back Cover: 手順 3、 2の画像 2
    • Gently slide the backside phone cover off exposing the battery underneath.
  4. Pantech Matrix Camera Button Replacement, Lift Battery: 手順 4、 1の画像 1
    • Carefully lift the battery up from where the spudger is pointed.
  5. Pantech Matrix Camera Button Replacement, Remove Battery: 手順 5、 1の画像 1
    • Remove the battery from its dock.
  6. Pantech Matrix Camera Button Replacement, Slide SIM Card Out: 手順 6、 3の画像 1 Pantech Matrix Camera Button Replacement, Slide SIM Card Out: 手順 6、 3の画像 2 Pantech Matrix Camera Button Replacement, Slide SIM Card Out: 手順 6、 3の画像 3
    • Slide the SIM Card out of its dock.
  7. Pantech Matrix Camera Button Replacement, Remove Phone Screws: 手順 7、 2の画像 1 Pantech Matrix Camera Button Replacement, Remove Phone Screws: 手順 7、 2の画像 2
    • Use a Phillips screwdriver to remove the four 2mm Phillips #000 screws from each corner of the device.
  8. Pantech Matrix Camera Button Replacement, Identify and Remove Phone Casing: 手順 8、 2の画像 1 Pantech Matrix Camera Button Replacement, Identify and Remove Phone Casing: 手順 8、 2の画像 2
    • Rotate the phone so the base is facing you.
    • Use spudger to separate phone casing and inside as shown.
    • Remove the casing carefully and set aside.
  9. Pantech Matrix Camera Button Replacement, Remove Camera Screws: 手順 9、 2の画像 1 Pantech Matrix Camera Button Replacement, Remove Camera Screws: 手順 9、 2の画像 2
    • Place phone with exposed motherboard facing you.
    • Use a Phillips screwdriver to remove the five 2mm Phillips #000 screws holding the camera in place.
  10. Pantech Matrix Camera Button Replacement, Identify and Remove Camera Button: 手順 10、 2の画像 1 Pantech Matrix Camera Button Replacement, Identify and Remove Camera Button: 手順 10、 2の画像 2
    • Carefully remove the motherboard to expose the camera button.
    • Grasp the camera button with a polypus and pull gently to remove the camera button.
終わりに
ある他の人がこのガイドを完成しました。
作成者
3人の作成者と共同で作成されました。
Zeel Patel
メンバー登録日: 10/13/14
1,096 ポイント
9のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 15
過去 30 日: 51
今までの合計 348
