メインコンテンツにスキップ
Pantech CDM8975 Screen Replacement
必要な工具と部品
  1. Pantech CDM8975 Screen Replacement, Screen: 手順 1、 1の画像 1
    • Open the flip phone so that the screen and keyboard are facing you.
  2. Pantech CDM8975 Screen Replacement: 手順 2、 1の画像 1
    • Remove the four screws at the corners of the screen.
  3. Pantech CDM8975 Screen Replacement: 手順 3、 2の画像 1 Pantech CDM8975 Screen Replacement: 手順 3、 2の画像 2
    • Use a spudger to separate the back shield from the top half of the phone.
    • Warning: Remove the battery prior to removing the screen.
  4. Pantech CDM8975 Screen Replacement: 手順 4、 1の画像 1
    • Set the phone down with the exposed side facing up.
  5. Pantech CDM8975 Screen Replacement: 手順 5、 1の画像 1
    • Near the hinge of the phone there is a green circuit board.
    • On the underside of the board, there is an orange plastic connector that connects the battery to the screen.
    • The LCD screen is the metal square with the black LCD screen in the middle (this should not be confused with the clear plastic protective screen on the front of the phone).
    • Pull the LCD screen out with your fingers and disconnect the circuit board from the orange plastic connector with the spudger.
  6. Pantech CDM8975 Screen Replacement: 手順 6、 1の画像 1
    • The original LCD screen will have components (like a microphone, speakers, etc.) attached by wires. If your replacement LCD screen is similar, then take out the original LCD screen (with attachments) and replace it with the new LCD screen. You can skip steps 8-11, since they do not apply to this situation.
    • Note: If your replacement LCD screen did not come with components (like microphone, speakers, etc.) attached, then continue with the guide as written.
    • Using wire cutters, disconnect the speaker from the phone.
    • Your phone will look different from these pictures, since the cutting steps have not been performed. Follow the steps in the guide for true instructions - pictures are only to help illustrate locations of steps.
  7. Pantech CDM8975 Screen Replacement: 手順 7、 1の画像 1
    • Pull the wires from the screen which connect to the speaker carefully.
  8. Pantech CDM8975 Screen Replacement: 手順 8、 2の画像 1 Pantech CDM8975 Screen Replacement: 手順 8、 2の画像 2
    • Carefully remove the screen. Leave the wires from the speakers exposed (top of the phone).
  9. Pantech CDM8975 Screen Replacement: 手順 9、 2の画像 1 Pantech CDM8975 Screen Replacement: 手順 9、 2の画像 2
    • Make sure all of the wires are out of the way before inserting new screen.
  10. Pantech CDM8975 Screen Replacement: 手順 10、 1の画像 1
    • Put the new screen into the phone.
    • Solder wires into screen if necessary.
  11. Pantech CDM8975 Screen Replacement: 手順 11、 1の画像 1
    • Reattach the backing of the phone with the four screws.
    • Your phone should now be operational (after reinserting the battery). If it is not, revisit the steps, and make sure everything was reassembled correctly.
    • If your phone turns on and displays, you are finished!
ゴール
作成者
10人の作成者と共同で作成されました。
Chris
メンバー登録日: 02/13/14
1 ポイント
1ガイドが承認済み
チーム
Ohio State, Team 1-4, Meza Spring 2014 Ohio State, Team 1-4, Meza Spring 2014人のメンバー
OSU-MEZA-S14S1G4
4 メンバー
4のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 5
過去 30 日: 14
今までの合計 557
