メインコンテンツにスキップ
Pantech Burst Motherboard Replacement
必要な工具と部品
  1. Pantech Burst Motherboard Replacement, Motherboard: 手順 1、 3の画像 1 Pantech Burst Motherboard Replacement, Motherboard: 手順 1、 3の画像 2 Pantech Burst Motherboard Replacement, Motherboard: 手順 1、 3の画像 3
    • Power off your phone before beginning disassembly.
    • Turn over the phone so that you're facing the back cover.
    • Locate the indent(?) below the back cover.
    • Using a fingernail, pull up to remove the back cover.
    • Removing the back cover may require some force.
  2. Pantech Burst Motherboard Replacement: 手順 2、 3の画像 1 Pantech Burst Motherboard Replacement: 手順 2、 3の画像 2 Pantech Burst Motherboard Replacement: 手順 2、 3の画像 3
    • Locate the silver battery. It is the big, rectangular, silver tape on black plastic object.
    • Find the gap between the battery and the rest of the device.
    • Using your fingernail, gently pull the battery up and away from the rest of the device.
  3. Pantech Burst Motherboard Replacement: 手順 3、 3の画像 1 Pantech Burst Motherboard Replacement: 手順 3、 3の画像 2 Pantech Burst Motherboard Replacement: 手順 3、 3の画像 3
    • Undo all 8 visible screws using a phillips size 000 screwdriver.
    • The screws are marked in red on the picture.
  4. Pantech Burst Motherboard Replacement: 手順 4、 2の画像 1 Pantech Burst Motherboard Replacement: 手順 4、 2の画像 2
    • Remove the SD card if there is one inserted into the phone.
  5. Pantech Burst Motherboard Replacement: 手順 5、 3の画像 1 Pantech Burst Motherboard Replacement: 手順 5、 3の画像 2 Pantech Burst Motherboard Replacement: 手順 5、 3の画像 3
    • Using an opening tool or some other solid, flat-ended tool, begin pulling apart the phone from the indent below the USB port.
    • Continue using the tool, while moving around the edge of the phone until the two parts are largely disengaged.
    • Once there is space enough to pull the pieces apart with your fingers, you may do so.
    • Opening the phone may require a good amount of force.
  6. Pantech Burst Motherboard Replacement: 手順 6、 3の画像 1 Pantech Burst Motherboard Replacement: 手順 6、 3の画像 2 Pantech Burst Motherboard Replacement: 手順 6、 3の画像 3
    • Unscrew the screw with a phillips size 000 screwdriver.
    • Disconnect the blue connector from the motherboard using a fingernail to lightly pull up.
    • Gently remove the SIM/SD card part.
  7. Pantech Burst Motherboard Replacement: 手順 7、 1の画像 1
    • Gently disconnect the connectors attached to the motherboard using a fingernail to pull them up from the board.
    • Connectors are marked in blue in the image.
  8. Pantech Burst Motherboard Replacement: 手順 8、 3の画像 1 Pantech Burst Motherboard Replacement: 手順 8、 3の画像 2 Pantech Burst Motherboard Replacement: 手順 8、 3の画像 3
    • Starting from the bottom and going around counterclockwise, carefully pry the motherboard out of the device.
    • Beginning with the side with the USB port may damage the phone.
終わりに
作成者
1人の作成者と共同作成されました。
Kyle Kurashima
メンバー登録日: 09/29/15
111 ポイント
1ガイドが承認済み
チーム
Cal Poly, Team 15-1, Green Fall 2015 Cal Poly, Team 15-1, Green Fall 2015人のメンバー
CPSU-GREEN-F15S15G1
5 メンバー
6のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 5
今までの合計 494
