メインコンテンツにスキップ
Pandigital Novel PRD07T10WWH7 Screen Replacement
必要な工具と部品
  1. Pandigital Novel PRD07T10WWH7 Screen Replacement, Screen: 手順 1、 1の画像 1
    • Remove the back panel by sliding it downwards and pushing in slightly.
  2. Pandigital Novel PRD07T10WWH7 Screen Replacement: 手順 2、 3の画像 1 Pandigital Novel PRD07T10WWH7 Screen Replacement: 手順 2、 3の画像 2 Pandigital Novel PRD07T10WWH7 Screen Replacement: 手順 2、 3の画像 3
    • Pry off the second white panel, removing two clips underneath.
    • Start from the middle, and then work on the sides. The sides may be difficult to remove, so try to focus on one side and work your way around.
  3. Pandigital Novel PRD07T10WWH7 Screen Replacement: 手順 3、 1の画像 1
    • Using a Phillips #0 bit, remove the 12 4mm screws on the outer area of the gray area exposed by removing the back panels.
  4. Pandigital Novel PRD07T10WWH7 Screen Replacement: 手順 4、 2の画像 1 Pandigital Novel PRD07T10WWH7 Screen Replacement: 手順 4、 2の画像 2
    • Carefully pry the back of the device from the front panel and motherboard. There are a series of clips holding them together that need to be separated.
  5. Pandigital Novel PRD07T10WWH7 Screen Replacement: 手順 5、 1の画像 1
    • Now, lift up the gray piece, unplug the battery connector, so the gray piece will come free from the rest of the device.
  6. Pandigital Novel PRD07T10WWH7 Screen Replacement: 手順 6、 2の画像 1 Pandigital Novel PRD07T10WWH7 Screen Replacement: 手順 6、 2の画像 2
    • Use the tip of your plastic spudger or your fingernail to flip up the long retaining flap. The longer, gold ribbon cable can now be pulled out safely.
  7. Pandigital Novel PRD07T10WWH7 Screen Replacement: 手順 7、 2の画像 1 Pandigital Novel PRD07T10WWH7 Screen Replacement: 手順 7、 2の画像 2
    • Use the tip of your plastic spudger or your fingernail to flip up the shorter retaining flap. The smaller gold ribbon cable can now be pulled out safely.
  8. Pandigital Novel PRD07T10WWH7 Screen Replacement: 手順 8、 2の画像 1 Pandigital Novel PRD07T10WWH7 Screen Replacement: 手順 8、 2の画像 2
    • Starting from the side of the device, lift the motherboard off of the plastic standoffs.
    • You will need to peel both speakers off of the device's plastic frame.
  9. Pandigital Novel PRD07T10WWH7 Screen Replacement: 手順 9、 2の画像 1 Pandigital Novel PRD07T10WWH7 Screen Replacement: 手順 9、 2の画像 2
    • With the screen facing up, use a plastic opening tool along the sides of the screen to pry it away from the motherboard.
    • There are six adhesive pads holding the display in place.
終わりに
2 の人々がこのガイドを完成させました。
作成者
2人の作成者と共同で作成されました。
Samuel Carey
メンバー登録日: 10/19/16
401 ポイント
3のガイドは作成済み
チーム
UMass Dartmouth, Team 3-7, Isaacson Fall 2016 UMass Dartmouth, Team 3-7, Isaacson Fall 2016人のメンバー
UMASSD-ISAACSON-F16S3G7
3 メンバー
10のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 7
今までの合計 775
