メインコンテンツにスキップ
Panasonic Toughbook CF-53 Wi-Fi Card Replacement
必要な工具と部品
  1. Panasonic Toughbook CF-53 Wi-Fi Card Replacement, Wi-Fi & Bluetooth Card: 手順 1、 3の画像 1 Panasonic Toughbook CF-53 Wi-Fi Card Replacement, Wi-Fi & Bluetooth Card: 手順 1、 3の画像 2 Panasonic Toughbook CF-53 Wi-Fi Card Replacement, Wi-Fi & Bluetooth Card: 手順 1、 3の画像 3
    • Turn the laptop to its back side and align it so that the handle is facing away from you.
    • Remove the single 4 mm Phillips #00 screw from the Wi-Fi card/optical drive cover and remove the plastic cover.
    • The Wi-Fi card is located closest to you , below the little strip-sized circuit board.
  2. Panasonic Toughbook CF-53 Wi-Fi Card Replacement: 手順 2、 2の画像 1 Panasonic Toughbook CF-53 Wi-Fi Card Replacement: 手順 2、 2の画像 2
    • Very gently pry up on the two connectors attached to the Wi-Fi card using the flat end of a spudger.
    • It is very important to be careful with these connectors because they are difficult to replace or repair.
    • Once both connectors have been detached, carefully hold the wires back to have access to the Wi-Fi card.
  3. Panasonic Toughbook CF-53 Wi-Fi Card Replacement: 手順 3、 3の画像 1 Panasonic Toughbook CF-53 Wi-Fi Card Replacement: 手順 3、 3の画像 2 Panasonic Toughbook CF-53 Wi-Fi Card Replacement: 手順 3、 3の画像 3
    • Remove the two 4 mm Phillips #00 screws that secure the card to the board.
    • Gently lift the card up and pull it out of its connection slot.
    • The Wi-Fi card is now removed.
    • When inserting the new Wi-Fi card into the connection slot, place the card at a 40 degree angle and push it all the way back, then lay it flat.
終わりに
作成者
4人の作成者と共同で作成されました。
Sean Marsden
メンバー登録日: 09/16/19
613 ポイント
5のガイドは作成済み
チーム
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 10
過去 30 日: 47
今までの合計 3,045
