はじめに
A common point of failure in many computers is the spinning mechanical hard drive. This drive may become corrupted, scratched, or otherwise broken if your computer suffers a serious fall or catastrophic drive failure. This guide shows how to operate the quick-swap drive caddy on the Panasonic Toughbook CF-53 and replace the physical hard drive in your device.
Any replacement drives must use the same 2.5" size standard to fit in the drive case.
必要な工具と部品
Locate the hard drive enclosure release latch in the top left corner. While pulling it down, lift the enclosure up and out of the laptop.
Flip the drive black side down.
Place six opening picks between the black outer casing and metallic inner casing to disengage the five metal clips connecting the inner and outer casings.
Once all the clips have been freed from their holes, you can now lift the inner casing up and out of the outer casing.
3 の人々がこのガイドを完成させました。
