メインコンテンツにスキップ
Panasonic Toughbook CF-29 Wireless Card Replacement
必要な工具と部品
  1. Panasonic Toughbook CF-29 Wireless Card Replacement, Battery: 手順 1、 1の画像 1
    • Locate the bay door for the battery on the left side of the laptop.
  2. Panasonic Toughbook CF-29 Wireless Card Replacement: 手順 2、 2の画像 1 Panasonic Toughbook CF-29 Wireless Card Replacement: 手順 2、 2の画像 2
    • Slide the latch to the right and then down to unlock it.
    • Pull out the battery.
  3. Panasonic Toughbook CF-29 Wireless Card Replacement, Back Cover: 手順 3、 1の画像 1
    • Begin by turning the laptop upside down with the handle towards you.
    • Use a Phillips size 0 screwdriver to remove the 4 screws holding down the ram cover.
  4. Panasonic Toughbook CF-29 Wireless Card Replacement: 手順 4、 1の画像 1
    • Remove the panel and set it aside.
    • Use a Phillips size 0 screwdriver to remove these 8 small screws.
  5. Panasonic Toughbook CF-29 Wireless Card Replacement: 手順 5、 1の画像 1
    • Use a Phillips size 1 screwdriver to remove the remaining 8 screws.
  6. Panasonic Toughbook CF-29 Wireless Card Replacement: 手順 6、 2の画像 1 Panasonic Toughbook CF-29 Wireless Card Replacement: 手順 6、 2の画像 2
    • Use a plastic opening tool to release, but NOT remove, the back cover because it is sealed with adhesive.
  7. Panasonic Toughbook CF-29 Wireless Card Replacement: 手順 7、 1の画像 1
    • Be careful when lifting the cover as you may damage some connections.
    • Slowly lift the cover so that you can disconnect the red and white wires connecting the speaker to the sound card.
  8. Panasonic Toughbook CF-29 Wireless Card Replacement: 手順 8、 1の画像 1
    • Now the back cover should be off and you can access the inside of the casing.
  9. Panasonic Toughbook CF-29 Wireless Card Replacement, Wireless Card: 手順 9、 1の画像 1
    • Remove the black and white wires attached to the wireless card by simply pulling up.
  10. Panasonic Toughbook CF-29 Wireless Card Replacement: 手順 10、 1の画像 1
    • Peel back the black cover to expose the clips holding in the wireless card.
  11. Panasonic Toughbook CF-29 Wireless Card Replacement: 手順 11、 1の画像 1
    • Using a pair of plastic opening tools, push the two metal tabs away from the card.
  12. Panasonic Toughbook CF-29 Wireless Card Replacement: 手順 12、 2の画像 1 Panasonic Toughbook CF-29 Wireless Card Replacement: 手順 12、 2の画像 2
    • The wireless card should now easily disengage from the motherboard.
    • Pull the card horizontally away from you to remove it from its housing.
終わりに
2 の人々がこのガイドを完成させました。
作成者
8人の作成者と共同で作成されました。
Devon Augustus
メンバー登録日: 04/12/10
130 ポイント
2のガイドは作成済み
チーム
Cal Poly, Team 27-93, Amido Spring 2010 Cal Poly, Team 27-93, Amido Spring 2010人のメンバー
CPSU-AMIDO-S10S27G93
4 メンバー
26のガイドは作成済み
コメント 1 件
what about the heatsinks of the processors? You don't fix the contact surface to the cover?
michael - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 5
過去 30 日: 15
今までの合計 14,683
