メインコンテンツにスキップ
Panasonic Toughbook CF-29 Touchscreen Replacement
必要な工具と部品
  1. Panasonic Toughbook CF-29 Touchscreen Replacement, Battery: 手順 1、 1の画像 1
    • Locate the bay door for the battery on the left side of the laptop.
  2. Panasonic Toughbook CF-29 Touchscreen Replacement: 手順 2、 2の画像 1 Panasonic Toughbook CF-29 Touchscreen Replacement: 手順 2、 2の画像 2
    • Slide the latch to the right and then down to unlock it.
    • Pull out the battery.
  3. Panasonic Toughbook CF-29 Touchscreen Replacement, Touchscreen: 手順 3、 1の画像 1
    • Remove the four hinge screws from the back of the computer.
  4. Panasonic Toughbook CF-29 Touchscreen Replacement: 手順 4、 2の画像 1 Panasonic Toughbook CF-29 Touchscreen Replacement: 手順 4、 2の画像 2
    • Open the laptop and remove the four indicated screws with a Phillips size 0 screwdriver.
    • Pry off the plastic strip which was previously held in place by the screws.
  5. Panasonic Toughbook CF-29 Touchscreen Replacement: 手順 5、 1の画像 1
    • Remove the four hinge screws to allow the hinges to rotate up and move.
  6. Panasonic Toughbook CF-29 Touchscreen Replacement: 手順 6、 1の画像 1
    • Remove 16 screws from the top of the closed laptop.
    • 12 Phillips size 1 screws
    • 2 Phillips size 0 screws
    • 2 Torx size 6 screws (T6)
    I found that the Torx screw on my model to be T8.
    Harley - 返信
    Is the touchscreen & the LCD 1 piece? or are they separate?
    Chasity Miller -
  7. Panasonic Toughbook CF-29 Touchscreen Replacement: 手順 7、 1の画像 1
    • Gently break the adhesive seal between the front and rear display cases with a plastic opening tool.
    • You will need to reapply the silicon adhesive during reassembly to ensure watertight seal.
  8. Panasonic Toughbook CF-29 Touchscreen Replacement: 手順 8、 1の画像 1
    • Pull the top halve of the casing up revealing the inside of the screen
  9. Panasonic Toughbook CF-29 Touchscreen Replacement: 手順 9、 2の画像 1 Panasonic Toughbook CF-29 Touchscreen Replacement: 手順 9、 2の画像 2
    • The top half of the case can be removed by sliding the tabs out from under the hinges.
    • This makes unplugging the screen wiring much easier
  10. Panasonic Toughbook CF-29 Touchscreen Replacement: 手順 10、 1の画像 1
    • There are 4 wires that need to be unplugged to remove the screen.
  11. Panasonic Toughbook CF-29 Touchscreen Replacement: 手順 11、 1の画像 1
    • For the first wire, peel back the silver cover tape to reveal the connection.
  12. Panasonic Toughbook CF-29 Touchscreen Replacement: 手順 12、 1の画像 1
    • Pull the wiring away from the connection to release it.
  13. Panasonic Toughbook CF-29 Touchscreen Replacement: 手順 13、 1の画像 1
    • Remove the 3 strips of black tape as shown to reveal connections 2 and 3.
    • Pull the wiring for each away from the connections to remove.
  14. Panasonic Toughbook CF-29 Touchscreen Replacement: 手順 14、 1の画像 1
    • The 4th connection is already visible.
    • Depending on your model it might not be plugged into anything. If it is, remove it the same way the other 3 connections were removed.
  15. Panasonic Toughbook CF-29 Touchscreen Replacement: 手順 15、 2の画像 1 Panasonic Toughbook CF-29 Touchscreen Replacement: 手順 15、 2の画像 2
    • Using a plastic opening tool, lift the screen as shown from the case and pull free.
終わりに
5 の人々がこのガイドを完成させました。
作成者
8人の作成者と共同で作成されました。
Dylan Bloom
メンバー登録日: 04/12/10
373 ポイント
4のガイドは作成済み
チーム
Cal Poly, Team 27-93, Amido Spring 2010 Cal Poly, Team 27-93, Amido Spring 2010人のメンバー
CPSU-AMIDO-S10S27G93
4 メンバー
26のガイドは作成済み
コメント 1 件
This guide is good for replacing the LCD screen, but it is not complete for the touchscreen panel, which requires some more delicate and precise steps. I think the title of the guide needs to be changed.
Thanks
Alessandro Cervelli - 返信
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 2
過去 30 日: 17
今までの合計 17,073
