メインコンテンツにスキップ
Panasonic Toughbook CF-29 Speaker Replacement
必要な工具と部品
  1. Panasonic Toughbook CF-29 Speaker Replacement, Battery: 手順 1、 1の画像 1
    • Locate the bay door for the battery on the left side of the laptop.
  2. Panasonic Toughbook CF-29 Speaker Replacement: 手順 2、 2の画像 1 Panasonic Toughbook CF-29 Speaker Replacement: 手順 2、 2の画像 2
    • Slide the latch to the right and then down to unlock it.
    • Pull out the battery.
  3. Panasonic Toughbook CF-29 Speaker Replacement, Back Cover: 手順 3、 1の画像 1
    • Begin by turning the laptop upside down with the handle towards you.
    • Use a Phillips size 0 screwdriver to remove the 4 screws holding down the ram cover.
  4. Panasonic Toughbook CF-29 Speaker Replacement: 手順 4、 1の画像 1
    • Remove the panel and set it aside.
    • Use a Phillips size 0 screwdriver to remove these 8 small screws.
  5. Panasonic Toughbook CF-29 Speaker Replacement: 手順 5、 1の画像 1
    • Use a Phillips size 1 screwdriver to remove the remaining 8 screws.
  6. Panasonic Toughbook CF-29 Speaker Replacement: 手順 6、 2の画像 1 Panasonic Toughbook CF-29 Speaker Replacement: 手順 6、 2の画像 2
    • Use a plastic opening tool to release, but NOT remove, the back cover because it is sealed with adhesive.
  7. Panasonic Toughbook CF-29 Speaker Replacement: 手順 7、 1の画像 1
    • Be careful when lifting the cover as you may damage some connections.
    • Slowly lift the cover so that you can disconnect the red and white wires connecting the speaker to the sound card.
  8. Panasonic Toughbook CF-29 Speaker Replacement: 手順 8、 1の画像 1
    • Now the back cover should be off and you can access the inside of the casing.
  9. Panasonic Toughbook CF-29 Speaker Replacement, Speaker: 手順 9、 1の画像 1
    • Place the back cover infront of you so you can access the inside of it.
    • Remove the 3 screws holding in the speaker.
  10. Panasonic Toughbook CF-29 Speaker Replacement: 手順 10、 1の画像 1
    • Pry out the speaker using a flat screw driver or a blue pry tool. It is held in with an adhesive.
  11. Panasonic Toughbook CF-29 Speaker Replacement: 手順 11、 1の画像 1
    • Your speaker is now removed
    • Put in your replacement by following the reverse steps.
終わりに
作成者
5人の作成者と共同で作成されました。
Rohun Heesen
メンバー登録日: 04/13/10
426 ポイント
2のガイドは作成済み
チーム
Cal Poly, Team 27-93, Amido Spring 2010 Cal Poly, Team 27-93, Amido Spring 2010人のメンバー
CPSU-AMIDO-S10S27G93
4 メンバー
26のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 19
今までの合計 5,366
