メインコンテンツにスキップ
Panasonic Toughbook CF-29 Motherboard Replacement
必要な工具と部品
  1. Panasonic Toughbook CF-29 Motherboard Replacement, Battery: 手順 1、 1の画像 1
    • Locate the bay door for the battery on the left side of the laptop.
  2. Panasonic Toughbook CF-29 Motherboard Replacement: 手順 2、 2の画像 1 Panasonic Toughbook CF-29 Motherboard Replacement: 手順 2、 2の画像 2
    • Slide the latch to the right and then down to unlock it.
    • Pull out the battery.
  3. Panasonic Toughbook CF-29 Motherboard Replacement, Hard Drive: 手順 3、 1の画像 1
    • Locate the door for the hard drive on the right side of the laptop
  4. Panasonic Toughbook CF-29 Motherboard Replacement: 手順 4、 2の画像 1 Panasonic Toughbook CF-29 Motherboard Replacement: 手順 4、 2の画像 2
    • Push and slide the latch up to open the hard drive door.
    • Pull out the hard drive.
  5. Panasonic Toughbook CF-29 Motherboard Replacement, Optical Drive: 手順 5、 1の画像 1
    • Flip the device upside down with the handle facing away from you.
    • Open the optical drive bay by sliding its latch to the right.
    • Locate optical drive release mechanism on the bottom of the laptop.
  6. Panasonic Toughbook CF-29 Motherboard Replacement: 手順 6、 1の画像 1
    • Slide the latch cover to the right.
  7. Panasonic Toughbook CF-29 Motherboard Replacement: 手順 7、 2の画像 1 Panasonic Toughbook CF-29 Motherboard Replacement: 手順 7、 2の画像 2
    • Push the exposed switch to the left to eject the optical drive.
  8. Panasonic Toughbook CF-29 Motherboard Replacement, Back Cover: 手順 8、 1の画像 1
    • Begin by turning the laptop upside down with the handle towards you.
    • Use a Phillips size 0 screwdriver to remove the 4 screws holding down the ram cover.
  9. Panasonic Toughbook CF-29 Motherboard Replacement: 手順 9、 1の画像 1
    • Remove the panel and set it aside.
    • Use a Phillips size 0 screwdriver to remove these 8 small screws.
  10. Panasonic Toughbook CF-29 Motherboard Replacement: 手順 10、 1の画像 1
    • Use a Phillips size 1 screwdriver to remove the remaining 8 screws.
  11. Panasonic Toughbook CF-29 Motherboard Replacement: 手順 11、 2の画像 1 Panasonic Toughbook CF-29 Motherboard Replacement: 手順 11、 2の画像 2
    • Use a plastic opening tool to release, but NOT remove, the back cover because it is sealed with adhesive.
  12. Panasonic Toughbook CF-29 Motherboard Replacement: 手順 12、 1の画像 1
    • Be careful when lifting the cover as you may damage some connections.
    • Slowly lift the cover so that you can disconnect the red and white wires connecting the speaker to the sound card.
  13. Panasonic Toughbook CF-29 Motherboard Replacement: 手順 13、 1の画像 1
    • Now the back cover should be off and you can access the inside of the casing.
  14. Panasonic Toughbook CF-29 Motherboard Replacement, Wireless Card: 手順 14、 1の画像 1
    • Remove the black and white wires attached to the wireless card by simply pulling up.
  15. Panasonic Toughbook CF-29 Motherboard Replacement: 手順 15、 1の画像 1
    • Peel back the black cover to expose the clips holding in the wireless card.
  16. Panasonic Toughbook CF-29 Motherboard Replacement: 手順 16、 1の画像 1
    • Using a pair of plastic opening tools, push the two metal tabs away from the card.
  17. Panasonic Toughbook CF-29 Motherboard Replacement: 手順 17、 2の画像 1 Panasonic Toughbook CF-29 Motherboard Replacement: 手順 17、 2の画像 2
    • The wireless card should now easily disengage from the motherboard.
    • Pull the card horizontally away from you to remove it from its housing.
  18. Panasonic Toughbook CF-29 Motherboard Replacement, Motherboard: 手順 18、 2の画像 1 Panasonic Toughbook CF-29 Motherboard Replacement, Motherboard: 手順 18、 2の画像 2
    • Unplug 3 cables
    • Lift up on brown tab to release cable
    • Pull cable up and out
  19. Panasonic Toughbook CF-29 Motherboard Replacement: 手順 19、 2の画像 1 Panasonic Toughbook CF-29 Motherboard Replacement: 手順 19、 2の画像 2
    • Remove 2 long screws indicated with red circles
    • Remove the remaining screws indicated in blue
  20. Panasonic Toughbook CF-29 Motherboard Replacement: 手順 20、 1の画像 1
    • On the back of the unit, unscrew the three screws surrounding the serial port.
  21. Panasonic Toughbook CF-29 Motherboard Replacement: 手順 21、 1の画像 1
    • Lift the motherboard as shown, pull towards you and then up.
    • Do not yet try to fully remove the motherboard or you may destroy the connections
  22. Panasonic Toughbook CF-29 Motherboard Replacement: 手順 22、 1の画像 1
    • Detach the white ribbon cable, the white cluster connector, and the ribbon cable right next to the cluster
  23. Panasonic Toughbook CF-29 Motherboard Replacement: 手順 23、 2の画像 1 Panasonic Toughbook CF-29 Motherboard Replacement: 手順 23、 2の画像 2
    • Remove the board.
終わりに
8 の人々がこのガイドを完成させました。
作成者
6人の作成者と共同で作成されました。
Dylan Bloom
メンバー登録日: 04/12/10
373 ポイント
4のガイドは作成済み
チーム
Cal Poly, Team 27-93, Amido Spring 2010 Cal Poly, Team 27-93, Amido Spring 2010人のメンバー
CPSU-AMIDO-S10S27G93
4 メンバー
26のガイドは作成済み
4 件のコメント
what about spare parts? is it possible cange MOBO and CPU?  in order to upgrade the thoughbook?
Concetto Salierno - 返信
I think y'all missed a step.
Gemini - 返信
Où acheter la carte mère?
MERCI
Pascal Cohu - 返信
Sur Google, recherchez "DL3UP1396AAA Panasonic CF-29 System Board" (à rechercher sans les guillemets), vous aurez quelques résultats (j'ai vu au moins 2 sites qui la propose à la vente), par contre, elle est cher.
Autre recherche possible : "DL3UP1396BAA Panasonic CF-29 System Board", je ne connais pas la différence entre ces variantes
Autre recherche possible : "DL3U11213FAA Panasonic CF-29 System Board", je ne connais pas la différence entre ces variantes
Brendan -
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 11
過去 30 日: 32
今までの合計 25,807
