メインコンテンツにスキップ
修理を始めるには
修理する権利
ストア
はじめに
This guide will show you how to remove the keyboard from the main unit.
パーツ
パーツは指定されていません。
  1. Locate the bay door for the battery on the left side of the laptop.
    • Locate the bay door for the battery on the left side of the laptop.
  2. Slide the latch to the right and then down to unlock it. Pull out the battery.
    • Slide the latch to the right and then down to unlock it.
    • Pull out the battery.
  3. Remove the four screws above the keyboard using a Phillips #0 screwdriver.
    • Remove the four screws above the keyboard using a Phillips #0 screwdriver.
  4. Pry up the black panel covering the top of the keyboard.
    • Pry up the black panel covering the top of the keyboard.
  5. The Essential Toolkit
    コンパクト版iFixitキットの中で最も利便性の高いツール
    ショップを見る
    ショップを見る
  6. Remove the five silver screws shown.
    • Remove the five silver screws shown.
  7. Pull up keyboard and place it face down on the trackpad
    • Pull up keyboard and place it face down on the trackpad
    • Be careful not to put tension in the ribbon cables attached to the underside of the keyboard
  8. Remove screws shown from cover plate
    • Remove screws shown from cover plate
  9. Pull cover plate out of place revealing the ribbon cable connections to the motherboard Pull cover plate out of place revealing the ribbon cable connections to the motherboard
    • Pull cover plate out of place revealing the ribbon cable connections to the motherboard
  10. Remove the ribbon cable farthest from you. Push the white tab (as shown in the second photo) to release the ribbon cable.
    • Remove the ribbon cable farthest from you.
    • Push the white tab (as shown in the second photo) to release the ribbon cable.
  11. Remove both ribbon cable by pulling 2 white tabs on either side of the cable to the right
    • Remove both ribbon cable by pulling 2 white tabs on either side of the cable to the right
終わりに
ある他の人がこのガイドを完成しました。
Dylan Bloom
メンバー登録日: 2010年04月12日
262 ポイント
4のガイドは作成済み
チーム
Cal Poly, Team 27-93, Amido Spring 2010 Cal Poly, Team 27-93, Amido Spring 2010人のメンバー
CPSU-AMIDO-S10S27G93
4 メンバー
24のガイドは作成済み
コメント1件
When replacing the KB, don'f forget the double sided fiberglass tape. The regular CF-29 KB is a backbone of thin aluminum sheeting, Most likely when you "pop" off the KB, its likely to bend. When you install a bent KB, it bounces when you type. Bend it back and tape it down with new tape. With the CF-30, removing that KB is totally different. Its locked down by brackets, not taped. You need to slide it forward unlocking it before popping it off, otherwise your KB keys start breaking. Be soft and confident, because you bet one chance to do it correctly. Sponsored by Black Hawk Toughbooks.
Black Hawk - 返信
コメントを追加
統計データを表示:
過去 24時間: 1
過去 7 日: 9
過去 30 日: 39
今までの合計 16,040
