メインコンテンツにスキップ
Panasonic SDR-H85 Hard Drive Replacement
必要な工具と部品
  1. Panasonic SDR-H85 Hard Drive Replacement, Battery: 手順 1、 3の画像 1 Panasonic SDR-H85 Hard Drive Replacement, Battery: 手順 1、 3の画像 2 Panasonic SDR-H85 Hard Drive Replacement, Battery: 手順 1、 3の画像 3
    • Gently slide the battery ejection button which is located underneath the battery and slide the battery out.
    • Once the battery is removed, you can safely dispose it and replace with a new one. Dispose battery at an authorized battery recycling center.
  2. Panasonic SDR-H85 Hard Drive Replacement, Hard Drive: 手順 2、 1の画像 1
    • Remove three Phillips #00 screws from the left-hand side of the camera.
  3. Panasonic SDR-H85 Hard Drive Replacement: 手順 3、 1の画像 1
    • Flip the camera so the bottom is facing upwards.
    • Remove four Phillips #00 screws to release the bottom portion of the camera panel.
  4. Panasonic SDR-H85 Hard Drive Replacement: 手順 4、 1の画像 1
    • Open up the charging port of the camera.
    • Hold the charging port flap open, and remove the single Phillips #00 screw.
  5. Panasonic SDR-H85 Hard Drive Replacement: 手順 5、 1の画像 1
    • This step needs to be done very slowly and carefully due to the delicate hard drive ribbon cable.
    • Open the camera cover slowly and enough to see the orange ribbon cable. Do not pull to release the ribbon cable from the hard drive.
    • Gently detach the connection of the ribbon cable from the hard drive by using the spudger to drive a wedge between the ribbon cable and the hard drive itself.
    • Do not use excessive force on the ribbon cable due to its delicate nature. You should feel a click when the connection has been broken.
  6. Panasonic SDR-H85 Hard Drive Replacement: 手順 6、 3の画像 1 Panasonic SDR-H85 Hard Drive Replacement: 手順 6、 3の画像 2 Panasonic SDR-H85 Hard Drive Replacement: 手順 6、 3の画像 3
    • Remove three Phillips #00 screws from the interior of the camera.
    • Carefully pull out the hard drive from both the top and the bottom in alternative moves, first from the top and then from the bottom.
    • Use slight force because the rubber lining around the hard drive is very secure.
    • Remove the rubber lining of the hard drive.
    • Make sure you remove the rubber lining carefully as it could pop through and potentially hit you.
終わりに
2 の人々がこのガイドを完成させました。
作成者
1人の作成者と共同作成されました。
Hamza Lodhi
メンバー登録日: 01/14/20
381 ポイント
2のガイドは作成済み
チーム
York University, Team S1-G8, Woodhouse Winter 2020 York University, Team S1-G8, Woodhouse Winter 2020人のメンバー
YORK-WOODHOUSE-W20S1G8
3 メンバー
6のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 21
今までの合計 692
