メインコンテンツにスキップ
Panasonic SDR-H40P SD Card slot Replacement
必要な工具と部品
  1. Panasonic SDR-H40P SD Card slot Replacement, Hard drive: 手順 1、 3の画像 1 Panasonic SDR-H40P SD Card slot Replacement, Hard drive: 手順 1、 3の画像 2 Panasonic SDR-H40P SD Card slot Replacement, Hard drive: 手順 1、 3の画像 3
    • Remove battery first.
    • Remove right side shell. There are two screws that are right behind the strap that also need to be removed.
    • Prepare to keep track of many tiny screws.
    • Keep track of where all your screws unscrew from. Some of these screws have a slightly different size compared to others and will get stuck inside the holes when putting it back together.
  2. Panasonic SDR-H40P SD Card slot Replacement: 手順 2、 3の画像 1 Panasonic SDR-H40P SD Card slot Replacement: 手順 2、 3の画像 2 Panasonic SDR-H40P SD Card slot Replacement: 手順 2、 3の画像 3
    • Remove indicated screws to release back panel.
  3. Panasonic SDR-H40P SD Card slot Replacement: 手順 3、 2の画像 1 Panasonic SDR-H40P SD Card slot Replacement: 手順 3、 2の画像 2
    • This is a continuation of Step 2.
    • Remove the last screw.
    • To remove the panel you simply pull it back.
    • There is a ribbon cable attached the the motherboard. Be sure to pull the panel back slowly, and detach the ribbon cable.
  4. Panasonic SDR-H40P SD Card slot Replacement: 手順 4、 3の画像 1 Panasonic SDR-H40P SD Card slot Replacement: 手順 4、 3の画像 2 Panasonic SDR-H40P SD Card slot Replacement: 手順 4、 3の画像 3
    • Remove the three screws highlighted in the pictures shown.
    • Do not use force on the hard drive.
    • To avoid damaging the device, slowly pick up the hard drive to reveal an orange ribbon cable attached to the motherboard pull back on the dark brown tab and carefully pull out the ribbon cable . Then you may proceed with removing the hard drive.
  5. Panasonic SDR-H40P SD Card slot Replacement, Motherboard: 手順 5、 2の画像 1 Panasonic SDR-H40P SD Card slot Replacement, Motherboard: 手順 5、 2の画像 2
    • Remove the screws circled.
    • Pull front section away from the rest of the camera to remove it.
    • Front panel has a ribbon cable that's attached to the motherboard. Detach the motherboard end when pulling off the front panel.
  6. Panasonic SDR-H40P SD Card slot Replacement: 手順 6、 3の画像 1 Panasonic SDR-H40P SD Card slot Replacement: 手順 6、 3の画像 2 Panasonic SDR-H40P SD Card slot Replacement: 手順 6、 3の画像 3
    • Carefully pull the motherboard away from the the rest of the camera.
    • Detach the ribbon cables from the motherboard.
    • Be careful with the ribbon cables they applying too much force could damage them.
  7. Panasonic SDR-H40P SD Card slot Replacement, Camera assembly: 手順 7、 2の画像 1 Panasonic SDR-H40P SD Card slot Replacement, Camera assembly: 手順 7、 2の画像 2
    • Remove screw circled.
    • Use a spatula to pull up the black shell and pull it away from the rest of the camera
  8. Panasonic SDR-H40P SD Card slot Replacement: 手順 8、 2の画像 1 Panasonic SDR-H40P SD Card slot Replacement: 手順 8、 2の画像 2
    • Remove the screw circled.
    • Feed the ribbon cable when pulling out the lens. There is a hole where the cable goes through. Do this before moving the lens.
  9. Panasonic SDR-H40P SD Card slot Replacement, SD Card slot: 手順 9、 3の画像 1 Panasonic SDR-H40P SD Card slot Replacement, SD Card slot: 手順 9、 3の画像 2 Panasonic SDR-H40P SD Card slot Replacement, SD Card slot: 手順 9、 3の画像 3
    この手順で使用する道具:
    購入する
    • Remove the two screws using a Phillips #00 screwdriver.
    • Use tweezers to slowly pull out the cable.
    • Pulling directly on the cord could lead to damaging the wire.
終わりに
作成者
3人の作成者と共同で作成されました。
Andrew Waldschmidt
メンバー登録日: 09/21/18
337 ポイント
4のガイドは作成済み
チーム
University of North Texas, Team S6-G6, Thompson Fall 2018 University of North Texas, Team S6-G6, Thompson Fall 2018人のメンバー
UNT-THOMPSON-F18S6G6
4 メンバー
10のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 7
今までの合計 161
