必要な工具と部品
Pull out the charging port (DC input terminal) cover and remove the 4-mm screw located next to the input terminal.
Flip out the LCD screen to expose the inner screws. Remove the two black 4-mm screws.
Using a firm hold on both sides of the camcorder, gently pull apart the casing under the hand strap.
Remove the black 4 mm screw located on the back of the camcorder under the SD card slot.
もう少しです!
終わりに
